  New Posts New Posts RSS Feed - x1 need 2 men to lift?
mans1000 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mans1000 Quote  Post ReplyReply Direct Link To This Post Posted: 21 January 2005 at 4:18pm
Lego?
Andrew View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andrew Quote  Post ReplyReply Direct Link To This Post Posted: 22 January 2005 at 4:03am
Meccano?
Need a lot of bolts to fill all the holes.
spaceman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote spaceman Quote  Post ReplyReply Direct Link To This Post Posted: 22 January 2005 at 7:57am
cling wrap?
JD01 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JD01 Quote  Post ReplyReply Direct Link To This Post Posted: 27 January 2005 at 4:54pm
Forget about plastic. We have subs made of plastic here in Germany and they don't get that much output, because much of the energy is wasted' in inflating/deflating the plastic housing. No joke, it's true...
Timber_MG View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Timber_MG Quote  Post ReplyReply Direct Link To This Post Posted: 27 January 2005 at 4:57pm
Actually, the thought was of a composite using plastic core material and fibre glass skins.
jerry View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerry Quote  Post ReplyReply Direct Link To This Post Posted: 28 January 2005 at 12:21pm
Hoo Timber,
I have been building boxes using a paper honeycomb material 3/4" thick and covering that with 1/8 balticbirch.Very labour intensive but my labhorns only weigh 100 lbs.
Cheers
JD01 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JD01 Quote  Post ReplyReply Direct Link To This Post Posted: 30 January 2005 at 8:14pm
@ Jerry: I order 12! :)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andrew Quote  Post ReplyReply Direct Link To This Post Posted: 31 January 2005 at 2:28am
Where do you get this material from Jerry?  Sounds just like what I am after!  How much is a sheet?
Phil B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Phil B Quote  Post ReplyReply Direct Link To This Post Posted: 31 January 2005 at 3:34am
Seems this box had been " designed " around carbonfibre? It says it`s " lightweight " for a double 15" ....still 80 kilos tho` which is as much as most ply boxes ? There`s so much " teknowaffle " as well to confuse people!!
http://www.qscaudio.com/products/speakers/isis/215pcm/215pcm .htm
.p.
norty303 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norty303 Quote  Post ReplyReply Direct Link To This Post Posted: 31 January 2005 at 7:15am
Yeah, but that 80 kilos includes a PL230 and a PL236 plus processors so it is a significant weight loss
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerry Quote  Post ReplyReply Direct Link To This Post Posted: 31 January 2005 at 11:31am
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerry Quote  Post ReplyReply Direct Link To This Post Posted: 31 January 2005 at 11:47am
Yoo Guys
I make this stuff myself,that is why it is labour intensive.However,a sheet of 48"by96"by1"only weighs about 13 lbs and cost me in material $30.00.I have worked with all kinds of carbonfibre,but this is not really a process that lends itself to the diy person.I can tell you how it is done and send you guys some pictures of the process,as long as you are not in a hurry,as my time is very limited.
Cheers
Jerry
