  New Posts New Posts RSS Feed - x1 on outdoors
x1 on outdoors
sonic boom View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sonic boom Quote  Post ReplyReply Direct Link To This Post Topic: x1 on outdoors
    Posted: 12 April 2005 at 6:58am
would x1 perform well outdoor? or prolly its better to have horns like 1850 or 186.
Currently i have 4 hd15. i am thinking of having 18s under them.
Cheers boomboom
whitehousejamie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote whitehousejamie Quote  Post ReplyReply Direct Link To This Post Posted: 12 April 2005 at 8:55am
I would just build more HD15s
JD01 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JD01 Quote  Post ReplyReply Direct Link To This Post Posted: 12 April 2005 at 9:06am
The X1 is a compact way to go really low. It's not as tight as a big stack of horns, but more compact. One X1 can go down that low.
So if you want a compact system then get two X1 under your four HD15, use a digital crossover and set it up properly. You can go loud and low then.
But if you want to grow larger then the 'build more HD15'-option would be better.
Mal X View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mal X Quote  Post ReplyReply Direct Link To This Post Posted: 12 April 2005 at 2:41pm
the x1's aint that good outside put them in inside and they will destroy all.
Mal, how loud was that!!!!!!
JD01 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JD01 Quote  Post ReplyReply Direct Link To This Post Posted: 12 April 2005 at 3:27pm
You'll need some more of them outside. A fact why the X1 sounds loud is the longer decay of the design. Indoors use extends this decay even further, so it sounds louder (it's psycho-acoustics again, the wacky friend of physics), but the sound gets more mushy (which isn't that noticeable below 60Hz). Outdoors, the sound is cleaner, tighter... but appears to be less heavy. This is the same for all resonator based designs.
This page was generated in 0.453 seconds.
