  New Posts New Posts RSS Feed - X1 pole mount to X15
Hobbyist2004 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hobbyist2004 Quote  Post ReplyReply Direct Link To This Post Topic: X1 pole mount to X15
    Posted: 21 March 2005 at 3:34pm
I'm using one X1 and one X15 per side right now, and I'd like to put a recessed pole mount adaptor on the  X1. Would this hurt the X1's performance in any way? Also,
would there be a weight issue with the X15?
Thanks
norty303 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norty303 Quote  Post ReplyReply Direct Link To This Post Posted: 21 March 2005 at 3:55pm
I can't see it being a problem as far as performance is concerned.  Just make sure you get the deep top hats as the depth of the port on the X15 means they're a bit front heavy where you have to mount the top hat
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hobbyist2004 Quote  Post ReplyReply Direct Link To This Post Posted: 21 March 2005 at 4:20pm
thanks norty, I wasn't aware of the X15 port issue. If I only had time to build 2 additional X1's or maybe some HD15's I wouldn't need the pole mounts. My only other option is that I do have 1 tripod, so I could purchase another and set the X1's on the inside of the tripod with the X15's on top.  I just wasn't sure if this would cause sound issues, but I think all the pole hardware with equal the price of an Ultimate tripod.
Edited by Hobbyist2004
Timber_MG View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Timber_MG Quote  Post ReplyReply Direct Link To This Post Posted: 22 March 2005 at 5:22am
I have built the cab and the port doesn't interfere with a good mouting of the top hat. I could place the top hat above the centre of gravity and don't use a deep top hat. In actual fact I would have preferred placing the top hat back a bit to give the cab a slight tendancy to lean forward.
