X1 Sizes for use with a 12" driver |
Post Reply | Page <12 |
csijo
Registered User Joined: 28 March 2005 Location: Venezuela Status: Offline Points: 102 |
OK i supposed but while i dont find the rigth sizes for build a god sub box for my drivers was the only thing that i thing. Thanks |
Audio Fanatics, Bass lover
LunchieTey
Young Croc Joined: 06 February 2005 Location: Australia Status: Offline Points: 934 |
The box sizes I suggested on the first page should work reasonably
well. Download WINisd and play around. But do not expect pro sound
output levels!
Speaker addict
csijo
Thanks LunchieTey I have a question in the message that you refer the sizes are in liters how i convert that to the sizes in cms for all the sides of the Box? Thanks LunchieTey you are the only one with enough interest to help me |
LunchieTey
Just get the volume-lets just use 70litres as an exmple. There's 1000cm3 per litre so that's 70000cm3. Pick two dimensions you'd like to use for the box-for example 40 and 35cm. So you just divide 70000 by 35 and then 40,that'll give you the final dimension. this gives 50cm. These are the INTERNAL dimensions and the volume of the speaker itself and ports etc must be ADDED to this.Then you'd do the same for the 30litre chamber(keeping two of the dimensions-35&40cm gives you 21.42cm) WinISD can show you the dimensions anyway,by just entering two dimensions(which is why I keep saying to download it!) So you'd end up with a box(using 18mm wood) about 77cm high by 38.6 wide and 43.6 deep(not including speaker dispacement and ports) Divide this box into a 50cm and 21.42 cm chamber and cut a hole in that divider for the speaker. |
Speaker addict
csijo
[QUOTE=LunchieTey] Thanks again Lunchie Tey If possible change the High for more deep to try get a more square box?
LunchieTey
The actual dimensions don't really matter,It's the volume of the box.
You can change any dimensions you want so long as the volume is the
same and the port sizes are right. WinISD allows you to change the
sizes and the others will change with it. Also the boxes you listed are
not all 6th order bandpass,some are for home theatre too so are not a
comparison. Don't forget to add the volume of the ports etc to the box
size.
Speaker addict
csijo
[QUOTE=LunchieTey] Ok Thanks Lunchie , |
csijo
[QUOTE=LunchieTey]
Lunchie Tey i make this design with new sizes you can review to ensure that is correct ? i use 70,79 liters instead of 70 the sizes are: h 52,09 x w 43 x d 45 cm and for the other chamber h 15,50 x w 43 x d 45cm ok very god . But now i want know the sizes for the ports i want use port similar to the X1 enclosure let me show you a draw |
LunchieTey
The X1 uses 'shelf' ports(using a piece of wood as wide as the front).
If you use the 45cm wide section of the box(internal measurement i
assume?) then make the port for the large chamber 3.5cm wide and 38cm
long with one brace in the middle (like the x1 ports) and the port for
the other chamber 3.5cm wide and 210mm deep.It's not really possible to
use bigger ports as they'll be really long(these should be enough
anyway) If you want big ports,the box will be much bigger and the ports
will have to be folded.
Use 18mm wood for the box(add 18mm thicknesses to the dimensions) and don't forget that the volume of these ports needs to be added to the box too(so your dimensions will need to be a little bigger) This box will have -3db points of 39hz and 100hz and -10db points of 32hz and 125hz. Continuous output will be about 122/123db or so for each box |
Speaker addict
