  New Posts New Posts RSS Feed - X1 sound?
X1 sound?
philip banyer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote philip banyer Quote  Post ReplyReply Direct Link To This Post Topic: X1 sound?
    Posted: 22 November 2004 at 1:42pm
X1
Using a Void 18inch driver, how much more base out put do you get from this x1 cabinet in relation too a normal sealed  box with 18inch driver.
Will my amp DAP 450 rms a channel in bridged s mode 900rms drive the Void driver ok?
I will have 4 HD 15s and just 1 x1
The use is for ballroom dance music which does not need lots of bass and does not need to be super loud even though it’s in a large sports hall.
Also does any one know how heavy the finished cabinet would be?
Thank you all for guiding me in the right direction.
This is a great web site
PBanyer
whitehousejamie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote whitehousejamie Quote  Post ReplyReply Direct Link To This Post Posted: 22 November 2004 at 5:30pm
Hi,
900watts is fine for the V18, ideally you want around 1000 to 1200watts to reduce the chance of amp clipping.
It would be better if you had a 2nd X1 in the system, but as you say you dont need much volume, 1 should work fine. Crossover between the X1 and HD15s at around 65hz.
Not exactly sure on the weight of the finished cabinet, but the V18 driver is pretty heavy, so i would guess around 50 to 60kg for the finished cabinet.
Regards
tb_mike View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tb_mike Quote  Post ReplyReply Direct Link To This Post Posted: 22 November 2004 at 11:08pm
Quote how much more base out put do you get from this x1 cabinet in relation too a normal sealed  box with 18inch driver.
No 18" for prosound will work effectively on a sealed box. Instead ported is used.
The bandpass offers several db over ported in SPL,loss of SQ is expected though I havent heard one.
