x1 sub with rcfl18p300? |
Post Reply | Page <1234> |
tb_mike
Old Croc Joined: 01 October 2004 Location: New Zealand Status: Offline Points: 2744 |
19mm is dangerously close to that woofers Xmech. Your way over xmax so it will sound terrible. Normally music has some varied level so that you most the time the power will be 256w-512watts and only 1600watts on peaks -Its music dependant. Even huge horns require large xmax if your looking for 140db everywhere! Note that against a wall its probably easier to try for 2 smaller mouthed horns that add -I bet that a horn for half space and 32hz is very difficult for you- I designed one lastweek and it was very tricky and large! Give me a PM if you want to discuss this further
Cheers! |
tb_mike
The answer is to boycott the BS audio manufacturers and demand they use real specs and not airey fairy rubbish! Lets do it! -Distortion graphs a la JBL type -DUMAX measured Xmax |
To clear things up. Thats a 453.1 liter (16 cubic feet) internal enclosure. The overall size of each box is 531.5 liters (18.77 cubic feet) |
minaximal
Old Croc Joined: 26 September 2004 Location: United Kingdom Status: Offline Points: 1780 |
Normally music has some varied level so that you most the time the power will be 256w-512watts and only 1600watts on peaks so whats the "standard" way of modelling a horn? ie. is it NOT ok to go to xmax on the rms/pmx rating and let it go over but below xmech for peak levels? |
tb_mike
No but im saying you wont always be at full power with music-some is peaky,some isnt. some drum n bass has basslines that are just continous -with fundamentals in the 32hz-42hz range all the time! Standard way-input RMS of amplifier and keep under xmax if you like good sound. Remembering that its best to have a speaker moving abit too far below its Xmech,than clipping your amp. But if your clipping your 800w RMS amplifier on a 105db/1watt horn...youl be deaf anyway |
staiper
Registered User Joined: 26 February 2004 Location: Croatia Status: Offline Points: 545 |
I have copied design from RCF book (suggested driver L18P300).. I have never build one so I cannot say anything about it's perpormance.. http://groups.msn.com/SpeakerBuildingpics/shoebox.msnw?actio n=ShowPhoto&PhotoID=24
Wigge
Registered User Joined: 18 October 2004 Location: Sweden Status: Offline Points: 12 |
more sugestions?
there must be alot of plans out to rcfl18p300? horns?
Daniel |
Jez_Ultra
Registered User Joined: 26 February 2004 Location: United Kingdom Status: Offline Points: 334 |
G-Sub as on the site |
tb_mike
if you want a horn design il fold one if you tell me enough requirements |
JD01
Young Croc Joined: 23 August 2004 Status: Offline Points: 819 |
He has a horn as well as a BR enclosure for the L18P300. The horn does 50Hz in single, but I wouldn't call it compact..... |
specialjustin
Young Croc Joined: 18 November 2006 Status: Offline Points: 555 |
Driver for that box is the l18s800
cyranotr
Registered User Joined: 13 December 2006 Location: Turkey Status: Offline Points: 6 |
I did an X1 box choosing on purpose the worst material for it = chip board(sample) as my driver for it is a B&C 18PWB46 wich has parameters far different from recommended. Nevertheless result is as expected. I can say very good clean, articulate, low extension bass reproduction. The diaphragm has load on both sides = transient response is good. But no 'slamm' !. But I suppose that no 'slamm' is to be connected to the design itself not to the driver inside. Do not expect 'kick' (means 80Hz-110Hz) area from this box. I do cut it at 85Hz and get almost the best controled deep bass ever (think about when cabinet will be made of plywood!!!). This subbass needs an additional BASS sub for the "kick" issue. I add for test purpose a 15" bass reflex box with...it fits! I'm about to to build the HD15 to get better output than bass reflex design. What is interesting in the x1 design is that it looks somehow like a bandbass (driver loaded on both sides) but does not sound like it. For my taste bandpass although well efficient provides always the same type of bass without 'articulation'. as you said. powww, powww, powww. The x1 can reproduce accurately an acoustic contrebass as well as a reggae electric bass guitar. And you hear the difference. Its loud, but weights differentely.
ROG in fact should tell us the change to be done according to driver or min parameters for this box to work fine. If you want I got a FFT measuring system with calibrated mic. I can send you what I got from my box (impedance, step, freq, phase).
Trust your ears...
