  New Posts New Posts RSS Feed - X1 tuned for 65-120hz?
Hobbyist2004 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hobbyist2004 Quote  Post ReplyReply Direct Link To This Post Topic: X1 tuned for 65-120hz?
    Posted: 06 December 2004 at 5:03am
If you wanted to stack an X1 on top of another, could you keep the bottom X1 normal for 32-65hz and re-work the top X1 (ports) to cover 65-120hz? This would be one way to have the same size cabs cover 32-120hz.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mobiele eenheid Quote  Post ReplyReply Direct Link To This Post Posted: 06 December 2004 at 11:38am
6th order bandpass cabs don't need to be that big for 65-120 Hz, so why bother? You could make something half the size of an X1 and still have plenty of output to go nicely with an X1.
On a Dutch forum someone is working on a Punisher that is 2' x 2' from the front, so it's made for standard trucksizes. Tho 2" deeper, it would fit pretty good, also when it comes to output.
http://www.licht-geluid.nl/forum/topic.asp?TOPIC_ID=12309
Cheers
freddyi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote freddyi Quote  Post ReplyReply Direct Link To This Post Posted: 06 December 2004 at 2:02pm
wonder how the throat would perform in version which appears to have cone parallel to a panel and firing "against"  that  panel? - is this a non-issue in sub?  - don't see view of initial throat section - but assume "V" ramps
how much would this version lower cutoff vs original Punisher?
Timber_MG View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Timber_MG Quote  Post ReplyReply Direct Link To This Post Posted: 06 December 2004 at 6:34pm
Exactly the same horn in theory, just re-worked to have a 60x60 front. V-throat as you thought (they have soem very nice CAD-drawings for these if you can hack through teh Duthc on speakerstore.nl)
Post Options Post Options   Thanks (0) Thanks(0)   Quote freddyi Quote  Post ReplyReply Direct Link To This Post Posted: 06 December 2004 at 6:44pm
Hi Martin - yeah (~same) - looks easier to  load/unload driver
This page was generated in 0.105 seconds.
