X1 tuned for 65-120hz? |
Hobbyist2004 ![]() Registered User ![]() Joined: 06 July 2004 Status: Offline Points: 99 |
![]() ![]() ![]() ![]() ![]() Posted: 06 December 2004 at 5:03am |
If you wanted to stack an X1 on top of another, could you keep the bottom X1 normal for 32-65hz and re-work the top X1 (ports) to cover 65-120hz? This would be one way to have the same size cabs cover 32-120hz.
mobiele eenheid ![]() Old Croc ![]() Joined: 15 August 2004 Location: Netherlands Status: Offline Points: 1568 |
6th order bandpass cabs don't need to be that big for 65-120 Hz, so why bother? You could make something half the size of an X1 and still have plenty of output to go nicely with an X1. On a Dutch forum someone is working on a Punisher that is 2' x 2' from the front, so it's made for standard trucksizes. Tho 2" deeper, it would fit pretty good, also when it comes to output. http://www.licht-geluid.nl/forum/topic.asp?TOPIC_ID=12309 Cheers |
freddyi ![]() Registered User ![]() Joined: 22 September 2004 Status: Offline Points: 936 |
wonder how the throat would perform in version which appears to have
cone parallel to a panel and firing "against" that panel? -
is this a non-issue in sub? - don't see view of initial throat
section - but assume "V" ramps
how much would this version lower cutoff vs original Punisher? |
Timber_MG ![]() Registered User ![]() ![]() Joined: 27 March 2004 Location: South Africa Status: Offline Points: 1454 |
Exactly the same horn in theory, just re-worked to have a 60x60 front.
V-throat as you thought (they have soem very nice CAD-drawings for
these if you can hack through teh Duthc on speakerstore.nl)
Hi Martin - yeah (~same) - looks easier to load/unload driver
