  New Posts New Posts RSS Feed - X1 using JBL 18" 1000w
stevieg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stevieg Quote  Post ReplyReply Direct Link To This Post Topic: X1 using JBL 18" 1000w
    Posted: 26 November 2013 at 10:57pm
Hi guys
Just signed up after browsing the forum yesterday.
I'm a mechanic by trade and have no real speaker box construction behind me other than helping to build a large box for a friends car.
I'm going to be building an X1 using a 1000w max JBL 18" as the driver bearing in mind it was never meant to  be the loudest thing on earth. Hopefully I will get a start on it with pictures over the weekend as I have a cut list from another romanian forum.
Steve
_djk_ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote _djk_ Quote  Post ReplyReply Direct Link To This Post Posted: 27 November 2013 at 12:37am
Model number please?
djk
Post Options Post Options   Thanks (0) Thanks(0)   Quote stevieg Quote  Post ReplyReply Direct Link To This Post Posted: 27 November 2013 at 9:51pm
I'll have to check as its in a box which I have not yet taken the driver out from.  Anyone know how many sheets of board are required for an X1 (yes I'm being lazy Tongue )
Edited by stevieg - 27 November 2013 at 9:52pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 27 November 2013 at 10:05pm
Are you talking about a car woofer? If yes, then please forget about the X1.
Post Options Post Options   Thanks (0) Thanks(0)   Quote stevieg Quote  Post ReplyReply Direct Link To This Post Posted: 27 November 2013 at 10:35pm
Whats wrong with a car woofer run with a crossover and 1600w amp
http://www.maplin.co.uk/p/prosound-2-channel-1600w-power-amplifier-n91fn
http://www.maplin.co.uk/p/prosound-crossover-l09an
Edited by stevieg - 27 November 2013 at 10:36pm
cravings View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cravings Quote  Post ReplyReply Direct Link To This Post Posted: 27 November 2013 at 10:46pm
right, that amp... you couldn't call that a 1600w amp at all. you'll have to aim higher. according to the specs you could bridge it into a driver and give it 800w.
4Ω stereo:     2 x 500Wrms
8Ω stereo:     2 x 250Wrms
8Ω bridged:     1 x 800Wrms
Max power:     1600Wmax @ 8Ω
driver, until you say what it is and we can look at the specs, no one will know if it's any use or not.
the X1 cab is notorious for eating unsuitable drivers. because of how the driver is loaded in the cab, it needs to have a really strong motor to survive in there making noise.
you can get a pair of X1s from 3 sheets of ply.
Post Options Post Options   Thanks (0) Thanks(0)   Quote stevieg Quote  Post ReplyReply Direct Link To This Post Posted: 27 November 2013 at 11:33pm
I'll have to get over to the lockup to get the woofer out tomorrow. I'll get some pics too.
This woofer won't be pushed hard most of the time if that makes any difference
Edited by stevieg - 27 November 2013 at 11:34pm
csg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote csg Quote  Post ReplyReply Direct Link To This Post Posted: 27 November 2013 at 11:43pm
if it is a car woofer, you are likely to get better results from a reflex enclosure, simpler to build too...
Or sell it and buy a half decent PA driver - say a second hand fane colossus XB which sounds great in modest reflex boxes. A PA driver will likely be far more sensitive, hence giving far greater output from your amplifier which may struggle with an insensitive driver.
Post Options Post Options   Thanks (0) Thanks(0)   Quote _djk_ Quote  Post ReplyReply Direct Link To This Post Posted: 27 November 2013 at 11:52pm
Car woofers are frequently designed to handle the stress of bandpass enclosures.
Let's hold off discussion until he comes up with a model number.
djk
bitSmasher View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bitSmasher Quote  Post ReplyReply Direct Link To This Post Posted: 28 November 2013 at 12:09am
PA subs in cars isn't the greatest idea, besides being huge... "cabin gain" in a car will boost the low end severly!
csg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote csg Quote  Post ReplyReply Direct Link To This Post Posted: 28 November 2013 at 12:22am
as the intended amplifier is a mains powered rack mount unit, i doubt the application is in car audio?
Post Options Post Options   Thanks (0) Thanks(0)   Quote stevieg Quote  Post ReplyReply Direct Link To This Post Posted: 28 November 2013 at 12:44am
your right, its not for car use.
