X1 vs MT2 |
Pinheiro ![]() Registered User ![]() ![]() Joined: 27 February 2004 Location: Portugal Status: Offline Points: 318 |
![]() ![]() ![]() ![]() ![]() Posted: 07 April 2005 at 2:50pm |
Hi I dont know the max spl off the X1 how many X1 to do the SPL off 8 MTL2 My interest is the X1 go lower then the MT2 but is good idea to sell the MT2 and make X1 or do some Lab sub?? Vivo (hope it is on the right forum) yours Vitor |
Lasse Lukkari ![]() Young Croc ![]() Joined: 09 March 2004 Location: Finland Status: Offline Points: 615 |
Don't worry... It's not that important |
whitehousejamie ![]() Young Croc ![]() Joined: 08 March 2004 Location: United Kingdom Status: Offline Points: 1485 |
I would say 3 X1s to 2 MT2 twin 18s |
JD01 ![]() Young Croc ![]() Joined: 23 August 2004 Status: Offline Points: 819 |
That is not a good comparison at all! The X1 does very well in the range between 35 and 60Hz whereas the MT2 doesn't do that at all much below 60Hz. The MTs provide a big hump in response around 60Hz and fall off below that. In addition they don't play that good above 100Hz. Those things are very narrow in their response. For replacing 8 MT2 I would recommend 6-8 X1s and something for the range above 60Hz, like HD15 or 1850 horns. 12 HD15 would do the trick. Ok, 12 HD15 plus 6 X1s are bigger than 8 MT2, but the sound will be much much better! |
Thanks The real pain is the MT2 (all 8) dont keap up whid my 8 HD215 and the 12 Turbo THL811.3 dont keap up whiad the HD´s the nest gool is to put the 30/40hz to 80hz on the same power off the HD´s (lots off heavy bass gig´s what to do X1 or labsub or ????? yours Vitor |
Depends.... If you want to be flexible you should go for X1. Six to eight of them should keep up with sixteen HD15 (or eight HD215 I guess). But you could split up the system if needed. If you go for LAB subs you'll get tighter sound, but you can't split up, because the LAB sub only works in big stacks (Ok, they work in less big stacks but they don't go as deep and that's the matter of an additional infra-way, is it?). I would crossover at 80Hz, but 60Hz. At 80Hz you waste a lot of potential of those HD215. And the X1 will play better if crossed at 60Hz.... Since the MT2 don't play well below 60Hz it's not a surprise they can't keep up with the HD215..... |
