  New Posts New Posts RSS Feed - X10 vs mt122 what would you use to go with ES18BPH
C-Audiofreak View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote C-Audiofreak Quote  Post ReplyReply Direct Link To This Post Topic: X10 vs mt122 what would you use to go with ES18BPH
    Posted: 07 December 2014 at 11:07pm
Hi guys I was going to build four of the mt122 cabs to go with my ES18 bph kicks and X1subs but have found that the original spec drivers that the plan states are no longer available but I can get everything for the x10 cab which would fair best with the kicks and subs I have mentioned?
Heathrow_B_line View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Heathrow_B_line Quote  Post ReplyReply Direct Link To This Post Posted: 08 December 2014 at 12:05am
most drivers will work with the mt122 or mt121
just ask the forum which drivers they would recommend for the mt122
Post Options Post Options   Thanks (0) Thanks(0)   Quote Heathrow_B_line Quote  Post ReplyReply Direct Link To This Post Posted: 08 December 2014 at 12:10am
PD121, PD123ER, B&C 12PE32, B&C 12NDL76, 18SOUND 12ND710, BMS 12S310, BMS 12S610, ETC
New P AUDIO 12" drivers are out too.  Im not sure what the model number is...possibly P-Audio SN2-12MB8
Edited by Heathrow_B_line - 08 December 2014 at 12:12am
DjLeco View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DjLeco Quote  Post ReplyReply Direct Link To This Post Posted: 08 December 2014 at 8:26am
Selenium 12MB3P.
Edited by DjLeco - 08 December 2014 at 8:27am
Post Options Post Options   Thanks (0) Thanks(0)   Quote C-Audiofreak Quote  Post ReplyReply Direct Link To This Post Posted: 08 December 2014 at 10:11am
Do you think 1 pair of mt122 would be enough th go with four x1 and 4 ES18BH ? Or would I be best going for two pairs?
cravings View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cravings Quote  Post ReplyReply Direct Link To This Post Posted: 08 December 2014 at 11:22am
the only reason to have 2 pairs of mt122 would be to cover a wider area really.
i've had 1 mt121 per side above 2 X1 and 2 double 15 a side.. has done fine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Heathrow_B_line Quote  Post ReplyReply Direct Link To This Post Posted: 08 December 2014 at 12:01pm
the x1 will run out of steam before the es18 or mt122 or mt121
king david View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote king david Quote  Post ReplyReply Direct Link To This Post Posted: 08 December 2014 at 3:55pm
+1
but that is largely dependent on crossover points and music selection
Post Options Post Options   Thanks (0) Thanks(0)   Quote C-Audiofreak Quote  Post ReplyReply Direct Link To This Post Posted: 08 December 2014 at 5:58pm
Why will the x1 run out of steam I'm hoping to run them upto 70hz then the ES18BPh 70-250hz and the mt122 250hz and up it will be mainly used for general purpous indie and rock and be used for general dance music when I'm dj'ing through it if these crossover points are wrong please advise me how I should set it up I want to get it right as sound quality is king for me and those using it I have already built the X1 subs so am committed with the sub end
cookie-dj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cookie-dj Quote  Post ReplyReply Direct Link To This Post Posted: 09 December 2014 at 6:17am
Neeeee naww someone's called the grammar police!
The MT's can outrun the x1, hence why you'd usually have 4x X1 (or even 4x 1850 horn) per MT. Cant really compare reflex tops to horn loaded, horn loaded will run rings around reflex tops outside though.
Depending on its usage, indoor/outdoor etc.
You can't polish a turd!
Post Options Post Options   Thanks (0) Thanks(0)   Quote C-Audiofreak Quote  Post ReplyReply Direct Link To This Post Posted: 09 December 2014 at 10:21am
Ok so maybe I will just build 1pair of 122's then will two es18 be enough for four x1 and one pair of mt122?
Post Options Post Options   Thanks (0) Thanks(0)   Quote cookie-dj Quote  Post ReplyReply Direct Link To This Post Posted: 09 December 2014 at 11:12am
Possibly.  what are the ES18 loaded with?
