X12 Horn Dispersion |
Forward Motion SS
Joined: 18 May 2009 Location: Shetland Isles Status: Offline Points: 271 |
Topic: X12 Horn DispersionPosted: 01 February 2010 at 8:59pm |
Hi, Just wondered what dispersion horns I would need for a pair of X12's that in some venues I'd use upright & some venues where theres not enough headroom I'd lay on there sides??
Am I right in thinking that a 90x90 or 100x100 would be ok or would that be to much coverage??
mikey bear
Joined: 29 October 2007 Status: Offline Points: 2379 |
Posted: 01 February 2010 at 9:17pm |
a lot of manufacturers use a square horn which can be unbolted and rotated for use on their sides. the void impulse and viper systems are examples of this
Forward Motion SS
Posted: 01 February 2010 at 10:23pm |
Anything you'd recommend? Rog designed the cab with a horn with a 45x45 dispersion, if I can't get or afford the Selenium what should I be looking for? The same dispersion & throat size??
ceharden
Posted: 01 February 2010 at 10:48pm |
I use a 60x40 dispersion horn on my X12-alikes and always thought I'd have dispersion problems but if you choose the location and angle of them well, I find the coverage is enough for almost all venues I work in.
Forward Motion SS
Posted: 03 February 2010 at 8:49pm |
Is that upright or on there side? Are they wired with an internal x over or with two inputs for the different frequencys?
Got the ply priced today @ £40 a sheet for bb grade but theres no wall saws up here so a joinery company will rip it down into more managable bits for me to work with! What sort of price do you pay a sheet??
