  New Posts New Posts RSS Feed - x12 or x15 with piezo?
Barrington View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Barrington Quote  Post ReplyReply Direct Link To This Post Topic: x12 or x15 with piezo?
    Posted: 16 September 2009 at 10:28pm
I want to build something like an x12 or 15 for a school project.  Just wondering if I use a piezo, does that mean I wont need a passive crossover in it?  How will a piezo go?
shadow1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shadow1 Quote  Post ReplyReply Direct Link To This Post Posted: 16 September 2009 at 11:03pm
Personally if i'm going to build a cab like the above mentioned i'll use a compression driver, like you said if it's for a school project, search for a cheap one & learn about it's frequencies & such forth then move on from there, but seriously forget the piezo.
Smile, the worst is yet to come.
breakdabeat pete View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote breakdabeat pete Quote  Post ReplyReply Direct Link To This Post Posted: 16 September 2009 at 11:03pm
piezos are simply utter rubbish!
avoid at all costs i say
٩(̾●̮̮̃̾•̃̾)۶
Post Options Post Options   Thanks (0) Thanks(0)   Quote Barrington Quote  Post ReplyReply Direct Link To This Post Posted: 17 September 2009 at 2:29am
ok yea i have heard before that they arent the best but didnt think they were that bad.  Il take ur advice.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Barrington Quote  Post ReplyReply Direct Link To This Post Posted: 19 September 2009 at 12:51am
I just recently came across those eminence beta coxial speakers.  Instead of having a compression driver, can i just use two 12" coxials in each enclosure for the X12 design?  Or even have one normal beta at the bottom, and then a coxial beta at the top?  I really dont want to be mucking around with crossovers.
Hugo Biermann View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hugo Biermann Quote  Post ReplyReply Direct Link To This Post Posted: 21 September 2009 at 4:11pm
You will still need a crossover. Build it properly and get done.
