  New Posts New Posts RSS Feed - X12 plywood thickness
sicoroots View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sicoroots Quote  Post ReplyReply Direct Link To This Post Topic: X12 plywood thickness
    Posted: 14 September 2017 at 7:33pm
Hi all...
I'm looking at a new build project of a pair of mid tops.
and also at the X12. For this one I'm still thinking if I want to modify it with only one 12" driver.
Original plan of the ( double 12" ) x12 uses 18 mm plywood...anyone made this with 15mm plywood ?
In case I modify it to a single 12"15mm plywood should work.. I built a modified SMT with one 12" and used 15mm wood
Also..the 18SOund plan has internal bracing pieces where the X12 doesn't.
I was wondering if anyone has used some sort of internal bracing for increased strength of the speaker
for example in the SMT 212 there isn't any plan for a bracing support for the comp driver + horn but I had to add it to mine to scure the tops avoiding all the weight to be supported only by the horn.
thanks !!
