x15 angles and cut sheets |
stephenwconcannon
Registered User Joined: 17 November 2007 Location: Ireland Status: Offline Points: 177 |
Posted: 30 January 2008 at 1:31am |
does anyone already have the angle and cu sheets make up for the x15s drawn out? save me alot of time
ceharden
Don't build X15's as-is. They're much bigger than they need to be for most applications. Choose your drivers then design a box round them. It's quite straightforward when you get into it...
stephenwconcannon
i have bought the drivers specified in the plan, why arnt the plans updated if they are inefficient ? are there updated plans ?
Edited by stephenwconcannon - 30 January 2008 at 2:31am |
ceharden
Which driver selection, did you go for the 1" HF or the larger option.
There's nothing really wrong with the plans, all I'm saying is that for a 15" reflex + compression driver box they're a bit big. You can build them as-is, or you can reduce the size to make them easier to cart about without loosing much in the way of performance. A lot of Rog's plans on the site are optimised for first time builders and as such are as simple as possible. There is scope to optimise them a bit. |
stephenwconcannon
the compression driver i went for is the bm-d740 would be nice to get small plans but i dont have the expeirence to modifiy the X15
Danmounter
Registered User Joined: 04 August 2006 Location: United Kingdom Status: Offline Points: 18 |
Would I be a million miles out in suggesting maybe cutting down the sizes to something closer to a Martin LE400 and keep the existing woofer, comp driver and xover network from the X15? Guidance from one of the more knowledgeable people on this forum might be able to suggest if I'm right. LE400 design is more easily transported, especially when cased in pairs, and adds the flexibility of two different angles during use.
I'm having an attempt at calculating the boxes I want in WinISD, and so far they look quite acceptable for live band use.
Dan
Mark James
well there you go then.
go for it.!!! |
Jake_Fielder
Old Croc Joined: 08 October 2007 Status: Offline Points: 4231 |
Did you build the original in the end? or did you modify it?
Zollax
Registered User Joined: 11 June 2008 Location: Sweden Status: Offline Points: 48 |
I would like to ask the same question. realy need to know the angle... Edited by Zollax - 02 October 2008 at 11:35am |
Reflux
New Member Joined: 25 September 2008 Status: Offline Points: 6 |
I'm working on the X15 at the moment and have drawn up my own cutsheets. I've done them by hand though so cannot post online, but the angle for the mitres is 10.7deg.
I found this tool really helpful for calculating angles: http://www.carbidedepot.com/formulas-trigright.asp Some basic trigonometry knowledge helps too! Edited by Reflux - 03 October 2008 at 8:07am |
Zollax
Thanks this was very helpful
