X15 Boxes |
Rog ![]() New Member ![]() Rogers Archive Posts Joined: 23 March 2010 Status: Offline Points: 2166 |
![]() ![]() ![]() ![]() ![]() Posted: 04 October 2004 at 10:07pm |
Hi Guys, Only new to all of this, I live Australia and my dad is a cabinet maker, its time for new boxes and I need exactly what the X 15 has to offer, I currently own two EV EVM-15L 400W 15" drivers that I would like to pair up with some horns. The X15 states a P-Audio 15" speaker and P-Audio Horn combination, . So my question is will my speaker work ok in this box and also where can I get the PAP VX1-VX2 crossovers from? Any help would be greatly appreciated, please email your reply to: Thanks in advance, Damian |
norty303 ![]() Old Croc ![]() ![]() Joined: 18 August 2004 Location: Eastbourne Status: Offline Points: 8802 |
The crossovers 'may' be available from Pro Audio PArts (link from the speakerplans homepage) When I ordered my drivers they didn't have any so they recommended the (I think) 3k2 xover which we had to add an 8db l-pad to.
Tom Umney ![]() Registered User ![]() ![]() Joined: 26 February 2004 Location: United Kingdom Status: Offline Points: 4954 |
The EVM-15L driver is not suitable for that box. The L at the end of that model, means Lead for lead guitar.
Edited by ToXiC |
IAIN RENDLE ![]() Registered User ![]() Joined: 23 May 2005 Location: United Kingdom Status: Offline Points: 836 |
hey guys looking for some PAP VX1's does any one know the Tech specs of them??? are there any other makes that do the same job? do any of the eminence x overs have same characteristics?
cheers |
LunchieTey ![]() Young Croc ![]() ![]() Joined: 06 February 2005 Location: Australia Status: Offline Points: 934 |
Cossovers are designed to suit specific driver combinations. It wll 'work' but may not sound as good as it could.If the HF driver/horn is the same it may be ok. The EVM-15L will also work fine in a ported box but may need to be tuned to suit the volume of the x15. Get the specs of the driver and put them into WinISD and model it. Looks fine on paper,qts .29 x-max 3.3mm etc,yes it is a 'guitar' speaker but is used in full range cabs aswell(like eminence with kappas/gammas etc) 'True' guitar speakers have short x-max but 3.3mm is plenty. Also the sensitivity appears higher so the HF pad may need adjusting |
Speaker addict
