  New Posts New Posts RSS Feed - X15 Drivers - 2014 - (£50-£100)
levyte357- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Topic: X15 Drivers - 2014 - (£50-£100)
    Posted: 22 April 2014 at 4:28pm
X15 Drivers - 2014 - £50-100 price range, used or new,
Not interested in heavy cone sub drivers, cab will not be used full-range, sub not a priority
What do people recommend, for use 100hz - 1.6khz?
For testing and house parties above sub, so no recommendations for spending more "please". LOL
Edited by levyte357- - 22 April 2014 at 4:30pm
all bass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote all bass Quote  Post ReplyReply Direct Link To This Post Posted: 22 April 2014 at 5:09pm
What about those Sovereign 15-500's you have? TS parameters seem within reasonable range.
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 22 April 2014 at 5:22pm
Need drivers with flatter response above 1.2khz in reflex, tall order for many 15" with 3"+ voice coil.
That's only reason I'm selling the pair of Fane Sov Pro 15-500s.
Actually needed drivers that are not as strong, with smaller voice coil. LOL
pfly View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pfly Quote  Post ReplyReply Direct Link To This Post Posted: 22 April 2014 at 11:49pm
More realistic crossover point for 15" mid would be somewhere around 600-800hz range, 1khz tops.
Why? Two reasons: beaming & cone resonance/breakup.
Of course if you are cheap and choose too small horn and compression driver, you'll end up with 1,6khz crossover or so... But that's just cheap and nasty.
Personally I have heard, tuned and measured enough examples of this.
Edited by pfly - 23 April 2014 at 12:11am
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 23 April 2014 at 1:03pm
If you are limited by cab size, you can't always fit huge 2" horn, & have to make do with 15"+1".
PD123ER & few other 15" drivers make decent attempt at 1khz-2khz, especially if cab not run below 80hz.
burningbush View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote burningbush Quote  Post ReplyReply Direct Link To This Post Posted: 23 April 2014 at 1:16pm
Still beams.
Post Options Post Options   Thanks (0) Thanks(0)   Quote burningbush Quote  Post ReplyReply Direct Link To This Post Posted: 23 April 2014 at 1:18pm
I have Gauss and gerbils that are cool upto there, but they are hard to find and for those with a light touch. I still use a 12 to bridge from the 15 to the 1", sounds nicer.
cravings View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cravings Quote  Post ReplyReply Direct Link To This Post Posted: 23 April 2014 at 1:23pm
blue aran had the pd153er on special a while ago... they're supposed to be pretty good up high.
i've only tried a few 15" reflex drivers in this setup, the old p-audio sn15mb is the one i've been the happiest with.
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 23 April 2014 at 1:38pm
Think combination of Correct 15", 1"/1.4" and engineering skills allows decent sound, be it at reduced SPL.
Otherwise, Rog wouldn't have suggested design for 15"+1", and many manufacturers wouldn't produce this, in powered format either.
Andy Kos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andy Kos Quote  Post ReplyReply Direct Link To This Post Posted: 23 April 2014 at 3:48pm
What sort of power handling do you need?
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 23 April 2014 at 4:18pm
Power handling not really the issue, 400W would suffice, if Ref efficiency 3.5%+.
Really need VC no larger than 2.5"-3", approx fs=50hz, and resp upto 2khz.
WILLZTHRILLZ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WILLZTHRILLZ Quote  Post ReplyReply Direct Link To This Post Posted: 23 April 2014 at 5:06pm
Hi, what about fane sovereign 15 400?   eff. 3.2% vc 2.5", fs 37hz
