  New Posts New Posts RSS Feed - X15 volume and xover
Hobbyist2004 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hobbyist2004 Quote  Post ReplyReply Direct Link To This Post Topic: X15 volume and xover
    Posted: 22 October 2004 at 7:07pm
Is the internal volume of the X15 aprox 6 cu. ft.
Also, if I needed for some reason to build my own crossover, have the specs been posted here before.
Thanks
Timber_MG View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Timber_MG Quote  Post ReplyReply Direct Link To This Post Posted: 22 October 2004 at 8:00pm
A crossover schematic for the X15 has been posted (not sure whether this if for the 1" version though), but this board has suffered under a hack and the design is no longer linked from the forum.
Martin
staiper View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote staiper Quote  Post ReplyReply Direct Link To This Post Posted: 23 October 2004 at 11:57pm
I have that page downloaded!
Post Options Post Options   Thanks (0) Thanks(0)   Quote staiper Quote  Post ReplyReply Direct Link To This Post Posted: 23 October 2004 at 11:59pm
C1  =  6   mf
C2  =  18 mf
L1  =  0.80 mh
L2  =  0.43 mh
R1  =  5    ohms
R2  =  4.7 ohms
tb_mike View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tb_mike Quote  Post ReplyReply Direct Link To This Post Posted: 25 October 2004 at 9:47am
pic doesnt work :( i can host it if u want.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tb_mike Quote  Post ReplyReply Direct Link To This Post Posted: 25 October 2004 at 9:56am
http://web.archive.org/web/*/http://http://www.speakerplans. com/
'wayback machine' old Internet site storage! -but was this crossover info on the page or the forum :s
Post Options Post Options   Thanks (0) Thanks(0)   Quote staiper Quote  Post ReplyReply Direct Link To This Post Posted: 25 October 2004 at 10:50am
attempt II...
Post Options Post Options   Thanks (0) Thanks(0)   Quote staiper Quote  Post ReplyReply Direct Link To This Post Posted: 25 October 2004 at 11:22am
B.T.W. I have finished my two way (SN15MB + BMD450+ PH220) cabinets and installed crossover that sounds best is ridiculously simple (6db/oct @ 2000Hz on bass and 6db/oct on 5600Hz on High-s)… P.audio PH220 horns have rising curve from around 5000Hz to lower freq. and this combination makes thing pretty flat..
Post Options Post Options   Thanks (0) Thanks(0)   Quote tb_mike Quote  Post ReplyReply Direct Link To This Post Posted: 25 October 2004 at 11:48am
have u got pics staiper? its great when simple stuff works!
Post Options Post Options   Thanks (0) Thanks(0)   Quote tb_mike Quote  Post ReplyReply Direct Link To This Post Posted: 25 October 2004 at 12:01pm
Could you use simple op amp circuit to equalise response and make the HPF down near where the LPF is ?
Im unsure of what horn type the PH220 could be CD i guess.
If you REALLY want you can do lots of things to try and get best results from these horn + 15" combo
Improvements in Monitor Loudspeaker Systems."
Tony Wilkes View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tony Wilkes Quote  Post ReplyReply Direct Link To This Post Posted: 25 October 2004 at 4:47pm
Have you used these yet with your Bandpass-Horn, if so how do they sound together
Post Options Post Options   Thanks (0) Thanks(0)   Quote Timber_MG Quote  Post ReplyReply Direct Link To This Post Posted: 25 October 2004 at 4:57pm
@ tbmike, though OPamp filter circuits are great for DIY audio at home, in pro-sound situations one needs something more rugged, generally with balanced inputs and outputs.
My only concern would be, whether the driver lives with a first order crossover. Most crossovers use a high pole for the first filter section and another set closer to intended x-over (CD horns only). Certainly seems like a very simple crossover and if it works it would be a gret budget alternative.
Is the posted x-over for the 1.5" version?
Martin
