X15 weight |
Fats
Registered User Joined: 23 October 2005 Status: Offline Points: 10 |
Posted: 12 October 2006 at 12:05pm |
Am totally clueless when it comes to guessing weight...
Anyone know the approx kg weight of an x15? Want to select the right tripod.. Cheers |
ceharden
If you're going to be tripod mounting an X15, build it smaller!
The X15 is a bit big for what it is, can be made more compact without
sacrificing much performance.
Fushion Julz
Registered User Joined: 19 August 2004 Status: Offline Points: 647 |
I built some XM15s exactlt to plan and made them pole mount...work nicely, too...
I'd reckon they are about 20-25Kg each |
Hugo Biermann
Young Croc Joined: 05 February 2005 Location: South Africa Status: Offline Points: 809 |
It all depends on the wood u use
Fushion Julz
Indeed...Mine were 18mm 13-lam Brazilian Ply
Andrew
Registered User Joined: 10 March 2004 Location: United Kingdom Status: Offline Points: 669 |
My 13-laminate ply must have been heavier than yours. The XM15 tops 30kg, if I remember correctly.
Insomnia
Old Croc Joined: 06 September 2005 Status: Offline Points: 1721 |
i built some Ev style t251+ from 18 marine ply about the same size as the xm15 but trapezoidal, it weighs nothing about 10 kg? add your neo drivers the hole cab loaded weighs around 15-17kg -which is nothing!
If your carpetting your top cabs go for marine ply, but if your painting go for birch or mdf
heres a pic
