X15 with two 15s? |
MixMan X
Joined: 18 July 2005 Location: United Kingdom Status: Offline Points: 382 |
Topic: X15 with two 15s?Posted: 28 September 2005 at 3:55pm |
Hi there guys, Anyone built a pair of X15's with two 15" divers instead of just the one? I'm wondering whether it would be best to double the internal volume or have two separate enclosures? Also, I would like to use the D750 2" compression driver with a bigger horn, any thoughts on this?
norty303
Joined: 18 August 2004 Location: Eastbourne Status: Offline Points: 8800 |
Posted: 28 September 2005 at 4:19pm |
Well the general concensus is that you should use 2 separate enclosures that way if one driver dies the remaining one is still operating in the same volume
MixMan X
Posted: 28 September 2005 at 4:26pm |
Good point, I'm wondering if I would get a bit lower bass with one large enclosure though? Also, I've just thought about the problem of a passive crossover capable of handling around 800w.
ceharden
Posted: 28 September 2005 at 7:45pm |
That sort of cabinet is going to have to be active to get the best out
of it. Probably also cheaper and easier than trying to make a big
enough passive x-over. You won't get any significant difference
in output between one large enclosure and one divided into two.
If you mean a B&C DE750 on a big horn, go for it, they're excellent CD's, used in some big name boxes. |
MixMan X
Posted: 29 September 2005 at 1:58am |
I was actually looking at the P Audio BMD750 comp driver?
ceharden
Posted: 29 September 2005 at 5:54am |
Sorry, too much of a B&C fan!
