  New Posts New Posts RSS Feed - X1
X1
whitehousejamie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote whitehousejamie Quote  Post ReplyReply Direct Link To This Post Posted: 15 October 2004 at 12:05am
I wonder how this new Void driver that is designed specifically for bandpass cabs will sound in the X1
Mal X View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mal X Quote  Post ReplyReply Direct Link To This Post Posted: 15 October 2004 at 9:21am
should be good its more powerful and has a bigger coil.
Mal, how loud was that!!!!!!
Jez_Ultra View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jez_Ultra Quote  Post ReplyReply Direct Link To This Post Posted: 16 October 2004 at 1:00pm
Mal are u using the V-18 1000, and if so how much are you sticking into each x1, where are you x-ing them over?
Jez
Post Options Post Options   Thanks (0) Thanks(0)   Quote whitehousejamie Quote  Post ReplyReply Direct Link To This Post Posted: 16 October 2004 at 3:00pm
Yes, he uses the V18 driver, and runs the 4 cabs off a Network 4, giving 900watts to each driver. I assume they get crossed over at 80hz.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mal X Quote  Post ReplyReply Direct Link To This Post Posted: 17 October 2004 at 11:06pm
ah you are right indeed, when i sort out some cash i will buy 2 infinate 8's to run my X1's give them a bit morer and let the cause hell!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote whitehousejamie Quote  Post ReplyReply Direct Link To This Post Posted: 17 October 2004 at 11:07pm
16kw of sub mmmm
Andrew View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andrew Quote  Post ReplyReply Direct Link To This Post Posted: 18 October 2004 at 12:15pm
Feels like a good starting point ... ?
