x1s vs scoops |
Post Reply | Page 12> |
abrupt
Young Croc Joined: 04 January 2006 Location: United Kingdom Status: Offline Points: 1074 |
Posted: 28 November 2007 at 5:34pm |
are x1s better for dnb techno and all other types of music and for indoors and outdoors
if so where would they out perform each other thanks
adambomb
Which Scoops?
X1s loaded with V1000?
abrupt
super scoops
p audio loaded
adambomb
SD18? I would stick with the X1s.. with a steep highpass at 30 - 35hz.. they take a lot to beat!
abrupt
what crossover filter would you say is best to run em on
adambomb
By all accounts the best crossover range seams to be :
high pass @ 35hz (24db or 48db slope)
low pass @ 63hz - 70hz (24db slope)... to HD15s (which is what I assume your running them with??).
This is from Doms experiments / measurments... and I can confirm it also works well with my own rig.
Cheers,
A.
sukebe
Registered User Joined: 07 June 2007 Status: Offline Points: 132 |
i've got X1's V1000 loaded and at the moment i dont have any HD's, so im running them up to about 90Hz, with my mid tops starting at about 110Hz and the X1's sound sick.
Cant wait to build some HD's or similar to add kick tho... |
mykey
Your forgetting something chaps
you keep talking about LOWS, but your forgetting the actual sound of a horn, especially a scoop
you can't beat it on D&B and dub etc
Don't worry Adam, I will get you to sell your X1's soon
levyte357
The 10,000 Points Club Joined: 10 May 2004 Location: UK, London Status: Offline Points: 11743 |
And I'm assuming all this is regarding indoors, right ? |
adambomb
I do exactly the same thing when using them as a small setup.. (X1s + A.S.S SP5)... 80 -90hz seam to be about right and as you say.. it is rather sick.. suprised you leave a gap between (perhaps this is because of the spec of your mid/tops?? Dont know what your using).
Mykey... something that beats X1s for the 30hz - 70hz has got to be very very good to get me to part with them!! Indoors OR out. Edited by adambomb - 29 November 2007 at 11:28am |
Mark James
so labs it is then lol.
adambomb
I would consider labs... but I would need 6 atleast for a nice stack (as in, to stack nicely)... lots a doller!
