  New Posts New Posts RSS Feed - Xenpow NSD
Xenpow NSD
djtuffer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote djtuffer Quote  Post ReplyReply Direct Link To This Post Topic: Xenpow NSD
    Posted: 25 September 2009 at 6:29pm
Anyone got any experience with Xenpow NSD-150 or cheap HTI-150 lamps.  Seen some for £20 each.  How do they compare with Osram HTI-150/152 ?
Cheers
csg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote csg Quote  Post ReplyReply Direct Link To This Post Posted: 26 September 2009 at 1:15pm
they dont - not for any time at least in my experience. there is also a big difference between the osram hti-150 and 152 - the 150 is the proper lamp, nice and bright, but with a shorter life than the 152 which has a much more yellow output, but a longer life
what ever you go for, make sure all your heads have the same lamps in or it looks a bit....
if you want cheaper lamps. look at the ge css150, very long life but again yellower outpu than the 150
