XM 15 pole mount |
IAIN RENDLE
Joined: 23 May 2005 Location: United Kingdom Status: Offline Points: 836 |
Topic: XM 15 pole mountPosted: 29 April 2006 at 10:40am |
has any one put a speaker stand pole mount on theres?? need 4 monitors and either i buy them or make 4 xm15's if i did make the XM15's i would need to pole mount them just incase i needed them for PA use. so if any one has. where is the best place to put them? dont want any thing that is gonna topple forwards!
iain |
-=vortex sound systems=-
www.vortexsound.co.uk |
norty303
Joined: 18 August 2004 Location: Eastbourne Status: Offline Points: 8800 |
Posted: 29 April 2006 at 11:32am |
My X15's have top hats and Dom's put top hats on his XM's. Just load the cabs and put a small piece of wood under each side and move the cab back and forth until it is resting very slightly forward. then mark this point and mount the top hat that far back from the front of the cab. Obviously it'll depend on whether you've used different drivers from spec as to where you will need to fix it.
IAIN RENDLE
Posted: 29 April 2006 at 11:34am |
if i do go ahead it will be with the correct drivers. thanks norty
cecild
Posted: 29 April 2006 at 10:36pm |
any advice on which tophats to use, cos they are prety heavy, ive got to x15s that i would like to use a monitors. Any advice on where to get a couple from? and some heavy duty stands. If anyone has any there are wanting to part with gimmie a shout! |
norty303
Posted: 30 April 2006 at 6:17am |
I ordered my top hats from Terralec, along with a load of other mounting hardware at the time. Seem to be fine and up for the job. Think my heavy duty stands came from there too. So long as they're rated for 40kg you'll be fine
Edward
Joined: 02 May 2006 Location: Russian Federation Status: Offline Points: 1 |
Posted: 02 May 2006 at 2:41pm |
I have BM15CX38. Please,help anybody! I need diagram
of crossover CX15 P audio. realine1@km.ru
Edward.
angus
Joined: 10 August 2005 Location: TW, Kent, UK Status: Offline Points: 516 |
Posted: 02 May 2006 at 4:44pm |
@Edward - you could start a new thread for this question, but a quick search for 'crossover schematic' on the forum came up with this thread, which looks like it has the required schematic. There have also been recent threads on the forum with regards to building ~600W passive xovers for these boxes (ceharden was the thread starter maybe)
Cheers, Angus P.S. Searchy search search ![]() P.P.S. You may well need to change the xover frequencies. PAP is currently shipping the VXM crossover as the recomended one for the SN15MB/BMD450 combo but your coasial driver may well benefit from different parameters - others may well be able help here. but if you have the design of the type of xover you need, modifying it to fit your needs should be easier... |
