Xmax, does it kill? |
Post Reply | Page <1234> |
luthier
Registered User Joined: 21 July 2013 Location: UK - London Status: Offline Points: 271 |
Saying this the 1550 has a higher MMS, larger voice coil, 2.5mm more xmax, low power compression and proven horn loading history.
ceharden
PD1550 would also make for a very heavy mid-top!
In terms of the cone, it's hard to tell from the specs, you can judge it better by looking and comparing them. I've got some RCF MB15H401's here which I'm wondering if I could get away with horn loading.
luthier
I agree and so do the sims, the response looks bad at the top end and very logarithmic overall. Looks like it would make very good thump at 80hz but not much use for anything else in this horn. Similar to the pd1850 and v18 in the Es18bph. I think the 12 version of that rcf is used in the Peter Morris mid top with good results, certainly looks good to me. I'll sim it tomorrow.
Edited by luthier - 26 January 2019 at 1:50am |
Crashpc
Registered User Joined: 26 February 2008 Location: Czech Republic Status: Offline Points: 463 |
Not that I would be sure about horn loading with 15ND76, but when I had these out, I could almost see through the surround, and the cone wasn´t like night and day sturdier by feel. I would not torture this one with high pressures. Also, if I remember well ,the cone was significantly more curvilinear than some other products. That is no good at the edge of the cone for high pressure. Anyway, hope you find some more valid info...
luthier
Thank you for the advice, I think it will just have to come down to a bit of testing on my part. From what I gather, hornloading drivers can be risky business, a strong motor and a stiff cone like on the pd1550 will take a good amount of abuse, but will be too heavy to reach higher frquencies and seem to have a very logarthmic response. Lighter cones like my ndl76 will play higher but ultimatley don't like small throats and high compression ratios and have a tendancy to rip cones if overdriven and/or unloaded. Hopefully I can work out a good driver through a bit of hornresp sims, guesstimating and real world testing. |
Crashpc
It´s funny that pd.1550 doesn´t have that much more Mms, yet it is perceived as significantly sturdier. Obviously, your plan is technically demanding, which is good, but it gets you cornered with issues like these. I wonder if interesting 12" couldn´t do betwen 100-500Hz... Just and idea. I also push things far, so I have sympathy for this. As usual, you´ll have to pay your experience with your wallet for broken cones. That´s what we all do unless some angel comes and helps us from our misery and clueless lifes. :-D
ceharden
The difference is most likely that the 1550 has a straight cone which is much stiffer than the curved or exponential cones which most bass-mid drivers have.
luthier
A straight cone I imagine would be loaded more evenly under high pressure but surely a cone with a curve in it causes it to be under a certain amount of extra tension, causing increased rigidity?
The force would be then be transferred to the surround, VC and spider which can guesstimate with the EBP. Surely this is the kind of experiment that pro audio companies do with FEA analysis. Edited by luthier - 31 January 2019 at 10:55pm |
fatfreddiescat
Young Croc Joined: 15 October 2010 Location: N.E.Wales Status: Offline Points: 1081 |
Looks like the 1550 is a curved cone, not as curved as some though, All the drivers used in the FK1’s I think are curved.
citizensc
Sorry to wake up a post from last page but I have experience using PD.153ERin xtros (horn loading them).
They hate it and will die. They will sound good for about 5 shows, then fall apart. |
ceharden
The cones drivers designed for 2-way mid tops etc are designed to flex such that at higher frequencies only the centre of the cone is moving and the outer section effectively stays still. This gives a better midrange performance but has an impact on cone strength.
As above, if you put too high an air load on any driver, asymmetric as you get on many bass horns is even worse, what you end up building is a confetti cannon! |
luthier
Well that is very useful to know.
