xover setting for w bin n Hd |
Future-House
Registered User Joined: 30 January 2015 Status: Offline Points: 83 |
Posted: 16 November 2017 at 11:23pm |
hi where should i cross these cabs? w-bin from 40hz to 80hz sound good then Hd from 80hz to 120hz is this ok?
then from 120hz up for the tops hope iv made it clear to understand
re-production
Registered User Joined: 16 February 2017 Location: Suffolk UK Status: Offline Points: 176 |
Thanks(1)
Completely depends on the W bin, how big is it? Best to guess first and then play around until it sounds good. Those seem like good starting points
Future-House
brilliant thank you, its a 18" i would say either an old fane or JBL design
currently loaded with a martin audio cinema 800w driver i thinks its a DLS
njw
Old Croc Joined: 26 March 2010 Location: S. Wales Status: Online Points: 2574 |
Thanks(1)
You'll probably get away with 150 on the HD's should you need to go higher to meet the tops. Don't go any higher though or they'll honk A LOT.
Future-House
diamond cheers :)
