XP running slow? |
Page 123 4> |
jbl_man ![]() Moderator Group ![]() Joined: 12 January 2005 Location: London. Status: Offline Points: 11043 |
![]() ![]() ![]() ![]() ![]() Posted: 15 December 2013 at 11:50am |
If anyone else is experiencing this,really slow response to commands etc,freezing up....its caused by the svchost running at 100% CPU,(or 50% on a dual-core) slowing everything up....to cure it,you need to install the latest update files from microsoft,but......however,trying to open windows update page just freezes it solid again,after about 6 attempts,and by switching the update time a few times,it will finally connect,and after downloading and installing about 15 update files,problem is cured.
I have done it on 4 different machines yesterday,so if anyone else has the problem,that's what to do. http://update.microsoft.com/microsoftupdate/v6/default.aspx?ln=en-us |
all bass ![]() Old Croc ![]() ![]() Joined: 11 October 2012 Location: the Netherlands Status: Offline Points: 1855 |
Maybe Microsoft trying to encourage you to move on to a newer version of their product...
Get your free line array plans here!
jammin75 ![]() Old Croc ![]() ![]() Joined: 08 July 2012 Location: west midlands Status: Offline Points: 2343 |
xp slow ?? runs like a rocket never had a glitch , freeze blue screen or anything it use it on my laptop that plays out never once had an issue
shagnasty ![]() Old Croc ![]() Joined: 30 July 2007 Location: Guildford, UK Status: Offline Points: 7685 |
hit windows+r, type msconfig and hit enter, then disable everything in your startup, see if that helps (you'll need to reboot to see if it worked)
Dub Specialist Sound ![]() Old Croc ![]() Joined: 15 November 2013 Location: Smethwick Status: Offline Points: 4873 |
XP dam right mine is terrible slow to upload pages and freeze's ect cant run a few tabs at the same time, takes ages to get going on e-bay for instance ,that blue circle thing keeps spinning for ages very anyoing
my pc is really old tbh tho all bass might be right there
mk2_ginger_biscuit69 ![]() Old Croc ![]() Joined: 03 November 2008 Location: Brighton Status: Offline Points: 7801 |
mine used to do that years ago when i ran XP, had to reinstall windows every time....
glad they finally found a fix for it! |
If the pc is old and just used for internet browsing and some office work, install Linux as it uses much less recources. That might help speed things up a bit.
Any of the bigger distros like Ubuntu etc. should be user friendly and easy to use. |
Cheers for that all bass,
and yes only for internet browsing , burning music very basic usage really. Thanks...
mini-mad ![]() Old Croc ![]() ![]() Joined: 13 July 2012 Location: london Status: Offline Points: 6903 |
wifeys pc... quad-core 2GB ram 120GB SSD. WINXP.... runs like a dream...and with a boot up that rivals newer pc's!
havent run updates since 06/12 never had one problem. NEVER. |
jazomir ![]() Old Croc ![]() Joined: 20 November 2006 Location: Sunderland UK Status: Offline Points: 1694 |
Just had to remove AVG (2014 Free) - started causing major problems on my XP-driven system after the latest Microsoft security update on Tuesday. Initially thought I might have a Rootkit infection - but several scans (using various antivirus software) AVG (AVGWDSVC.EXE) started eating into my CPU utilisation, I started having BSODs and eventually had to reboot in safe mode and fully remove AVG to solve the problem. I use BT Cloud for safe offsite storage and can't get this to work locally so may need to contact BT but I still suspect the MS update caused the problem. I will keep you informed of any further info I recieve.
...yes moved off AVG 2yrs ago. use to be good now its just bloated to buggery. dont use zonealarm any more either... it distroys your CPU in double quick time.
have a look at comodo internet security suite. its free and works.
Fumper ![]() Registered User ![]() ![]() Joined: 31 May 2013 Status: Offline Points: 13 |
Dont know if this will affect xp users but microsoft will no longer be doing updates for xp after 2013 and as from April 2014 it will no longer be supported :(
Page 123 4> |
