  New Posts New Posts RSS Feed - XP running slow?
XP running slow?
Post Options Post Options   Thanks (0) Thanks(0)   Quote jbl_man Quote  Post ReplyReply Direct Link To This Post Topic: XP running slow?
    Posted: 15 December 2013 at 11:50am
If anyone else is experiencing this,really slow response to commands etc,freezing up....its caused by the svchost running at 100% CPU,(or 50% on a dual-core) slowing everything up....to cure it,you need to install the latest update files from microsoft,but......however,trying to open windows update page just freezes it solid again,after about 6 attempts,and by switching the update time a few times,it will finally connect,and after downloading and installing about 15 update files,problem is cured.
I have done it on 4 different machines yesterday,so if anyone else has the problem,that's what to do.
http://update.microsoft.com/microsoftupdate/v6/default.aspx?ln=en-us
all bass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote all bass Quote  Post ReplyReply Direct Link To This Post Posted: 15 December 2013 at 1:15pm
Maybe Microsoft trying to encourage you to move on to a newer version of their product...
jammin75 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jammin75 Quote  Post ReplyReply Direct Link To This Post Posted: 15 December 2013 at 1:33pm
xp slow ??  runs like a rocket never had a glitch , freeze blue screen or anything it use it on my laptop that plays out never once had an issue Smile
shagnasty View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shagnasty Quote  Post ReplyReply Direct Link To This Post Posted: 15 December 2013 at 1:36pm
hit windows+r, type msconfig and hit enter, then disable everything in your startup, see if that helps (you'll need to reboot to see if it worked)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dub Specialist Sound Quote  Post ReplyReply Direct Link To This Post Posted: 15 December 2013 at 3:35pm
XP dam right mine is terrible slow to upload pages and freeze's ect cant run a few tabs at the same time, takes ages to get going on e-bay for instance ,that blue circle thing keeps spinning for ages very anyoing
my pc is really old tbh tho
all bass might be right there
Post Options Post Options   Thanks (0) Thanks(0)   Quote mk2_ginger_biscuit69 Quote  Post ReplyReply Direct Link To This Post Posted: 15 December 2013 at 3:52pm
mine used to do that years ago when i ran XP, had to reinstall windows every time....
glad they finally found a fix for it!
Post Options Post Options   Thanks (0) Thanks(0)   Quote all bass Quote  Post ReplyReply Direct Link To This Post Posted: 15 December 2013 at 3:54pm
If the pc is old and just used for internet browsing and some office work, install Linux as it uses much less recources. That might help speed things up a bit.
Any of the bigger distros like Ubuntu etc. should be user friendly and easy to use.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dub Specialist Sound Quote  Post ReplyReply Direct Link To This Post Posted: 15 December 2013 at 4:10pm
Cheers for that all bass,
and yes only for internet browsing , burning music very basic usage really.
Thanks...
mini-mad View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mini-mad Quote  Post ReplyReply Direct Link To This Post Posted: 15 December 2013 at 4:18pm
wifeys pc... quad-core 2GB ram 120GB SSD. WINXP.... runs like a dream...and with a boot up that rivals newer pc's!
havent run updates since 06/12 never had one problem. NEVER.
jazomir View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jazomir Quote  Post ReplyReply Direct Link To This Post Posted: 15 December 2013 at 5:37pm
Just had to remove AVG (2014 Free) - started causing major problems on my XP-driven system after the latest Microsoft security update on Tuesday. Initially thought I might have a Rootkit infection - but several scans (using various antivirus software)  AVG (AVGWDSVC.EXE) started eating into my CPU utilisation, I started having BSODs and eventually had to reboot in safe mode and fully remove AVG to solve the problem. I use BT Cloud for safe offsite storage and can't get this to work locally so may need to contact BT but I still suspect the MS update caused the problem. I will keep you informed of any further info I recieve.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mini-mad Quote  Post ReplyReply Direct Link To This Post Posted: 15 December 2013 at 5:45pm
...yes moved off AVG 2yrs ago. use to be good now its just bloated to buggery. dont use zonealarm any more either... it distroys your CPU in double quick time.
have a look at comodo internet security suite. its free and works.
Fumper View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fumper Quote  Post ReplyReply Direct Link To This Post Posted: 15 December 2013 at 5:46pm
Dont know if this will affect xp users but microsoft will no longer be doing updates for xp after 2013 and as from April 2014 it will no longer be supported :(
This page was generated in 0.108 seconds.
