  New Posts New Posts RSS Feed - XP running slow?
XP running slow?
Post Options Post Options   Thanks (0) Thanks(0)   Quote jbl_man Quote  Post ReplyReply Direct Link To This Post Posted: 15 December 2013 at 6:08pm
Originally posted by jazomir jazomir wrote:
Just had to remove AVG (2014 Free) - started causing major problems on my XP-driven system after the latest Microsoft security update on Tuesday. Initially thought I might have a Rootkit infection - but several scans (using various antivirus software)  AVG (AVGWDSVC.EXE) started eating into my CPU utilisation, I started having BSODs and eventually had to reboot in safe mode and fully remove AVG to solve the problem. I use BT Cloud for safe offsite storage and can't get this to work locally so may need to contact BT but I still suspect the MS update caused the problem. I will keep you informed of any further info I recieve.
Ditto that Trevor, the latest 2014 AVG just makes XP run rediculiously slowly...i removed mine as well.Now using Avast ,seems much better,no problem.
jazomir View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jazomir Quote  Post ReplyReply Direct Link To This Post Posted: 15 December 2013 at 7:14pm
Originally posted by Fumper Fumper wrote:
Dont know if this will affect xp users but microsoft will no longer be doing updates for xp after 2013 and as from April 2014 it will no longer be supported :(
April 8th 2014 is the date to remember. There are already warnings of masses of exploit attacks since MS will no longer be issuing security patches/fixes to avoid/repair such problems. It's a pity really when there are literally tens of millions of people still using XP who have no need for a more 'advanced' operating system and the learning curve required with its installation.
Here are a couple of useful links regarding the latest @Tuesday Patch':  http://pcsupport.about.com/b/2013/12/10/patch-tuesday.htm
Edited by jazomir - 15 December 2013 at 7:20pm
shagnasty View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shagnasty Quote  Post ReplyReply Direct Link To This Post Posted: 15 December 2013 at 7:21pm
TBH, unless you have every port forwarded on your router to your internal IP and run no AV software, I don't see the issue, I know of 100s of boxes that never recive any updates and none have burst into flames or stolen the family car.
XP is 10 years old, I real terms is 32bit (xp-64 is not that common and driver support, is at best random) so if anyone is using it at the min it is probably on older hardware and if it does what you want now it will do that in 4 years time, I have machines that I have never updated and they work fine...
Personally I will be sticking with W7-x64 for some time, W8 is dead in the water and XP can't deliver the power I need.
But please, no one spend cash just because MS won't be dicking with your OS every 5mins anymore!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dub Specialist Sound Quote  Post ReplyReply Direct Link To This Post Posted: 15 December 2013 at 9:07pm
So what are you saying that it will be ok/safe to run xp after the April 2014 , only do internet browsing listen to radio, ebay/YT go on my bank ect , as i said earlier very basic usage...dont need it to any more high tec stuff,
only asking as i do not know what all this tec-talk is about pcs...
thanks...
Post Options Post Options   Thanks (0) Thanks(0)   Quote shagnasty Quote  Post ReplyReply Direct Link To This Post Posted: 15 December 2013 at 9:19pm
pretty much, run a decent AV/intrusion prevention package, I use Norton Internet Security for most single machines, keep that up to date, don't download dodgy stuff and you will be fine, I had a NT 4 server running until last year, I don't know if NT ever updated, I know it didn't even have the lastest service pack on it, worked fine, replaced with a dual Xeon machine that runs about 10 x faster and generates about a third the heat!!!!!
Thinking back, that dual P3 Xeon box must have cost a few quid in electricity over the 15 years it was in my loft!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dub Specialist Sound Quote  Post ReplyReply Direct Link To This Post Posted: 15 December 2013 at 9:49pm
Thanks Shag,
im on Virgin Media Security allways have been,  dont know if that still sufficient still?
Post Options Post Options   Thanks (0) Thanks(0)   Quote shagnasty Quote  Post ReplyReply Direct Link To This Post Posted: 15 December 2013 at 10:04pm
I use virgin as an ISP but I have no idea what their security is like, but I am assuming it is fine as it is not in their interests to have the support impact of a crap package...
djeddie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote djeddie Quote  Post ReplyReply Direct Link To This Post Posted: 15 December 2013 at 10:11pm
Back to Ian's original statement, it's from "Patch Tuesday"...
which Micro$oft should rename "Patch Tuesday, Wednesday, Thursday, Friday, Saturday and Sunday. During which time your PC will be almost unusable, even though we won't put anything on your screen to warn you of what's happening. And we'll see just how many times we can make you restart your PC without you writing a snotty email to the Customer Services team".
Admittedly, "Patch Tuesday" is bit 'catchier'!
levyte357- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 16 December 2013 at 12:20am
C'mon guys,
Just get a 4gb Core 2 Duo/Quad DELL machine, and upgrade to Windows '7 for free.
Leave all these XP woes behind. Wink
jammin75 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jammin75 Quote  Post ReplyReply Direct Link To This Post Posted: 16 December 2013 at 1:47am
C'mon guys,
mine is a 4gb core2 duo dell runnin xp one thing though mine doesnt go online its only used to run music when playin out on set Smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote jazomir Quote  Post ReplyReply Direct Link To This Post Posted: 18 December 2013 at 10:18pm
I just got rid of both AVG & AdAware and moved to AVAST. It seems a lot less intrusive and resource hungry than the packages it replaces but I am still having major problems with my HDD light on almost permanently, CPU utilisation still going up & down like a yoyo with no applications running and my BT stuff still doesn't work. My machine is usable - just - but I am determined to find out the root cause of the problem (my money is still on the latest MS Patch Tuesday release, but it's difficult to pin it down conclusively).
Post Options Post Options   Thanks (0) Thanks(0)   Quote mk2_ginger_biscuit69 Quote  Post ReplyReply Direct Link To This Post Posted: 18 December 2013 at 11:55pm
so i've come home for xmas, and am using my trusty EEE netbook running XP....
I have the scvhost issue, but i can't get microsoft update to work, sticks on the 'searching for updates' bit - any tips?
This page was generated in 6.781 seconds.
