  New Posts New Posts RSS Feed - XTA power issues
XTA power issues
Uredheer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Uredheer Quote  Post ReplyReply Direct Link To This Post Topic: XTA power issues
    Posted: 13 November 2023 at 12:19pm
Hello!!
XTA dp448 gone a bit weird.
Doesn't fully load up when powered 13a.. display lights up green but no other LEDs or text..
When plugged into 16a - 13a distro, works perfect.
Wats going on here?
Thanks
DMorison View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMorison Quote  Post ReplyReply Direct Link To This Post Posted: 13 November 2023 at 1:26pm
1st thing I'd check is the outlet/cabling used for the 13A test, make sure there's no swapped connections or floating grounds etc.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Uredheer Quote  Post ReplyReply Direct Link To This Post Posted: 13 November 2023 at 1:35pm
Tested on multiple outlets and multiple kettle leads..
Only difference made was plugging into our distro (coming from 16a outlet) rather than directly into 13a mains.
Tinnitus Rex View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tinnitus Rex Quote  Post ReplyReply Direct Link To This Post Posted: 13 November 2023 at 2:23pm
it cannot be a problem with the XTA. Measure your "13amps" Voltage with a plug in monitor or multimeter if you can. Are you in a 230v or 110v zone?
Edited by Tinnitus Rex - 13 November 2023 at 2:43pm
"couldn't we just like... use headphones?"
teeth View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote teeth Quote  Post ReplyReply Direct Link To This Post Posted: 13 November 2023 at 2:29pm
weird...
i know there is documented issues with the top board that deals with the screens on these units. but thought they solved that with the Dp4 models...
i would pop it open and check all ribbon connections etc, something could be loose or cold inside...
