X-tro 15 in HornRESP |
antimony
Registered User Joined: 18 October 2004 Location: United Kingdom Status: Offline Points: 105 |
Posted: 28 April 2007 at 8:19pm |
Hi im planning to build some 15 inch horns that will play similar range to the 15 section of the X-tro. Can someone post the input parameters for HornResp please, i dont understand if the horns use the double mouth area or the single and my sims are comig out looking bad.
Would it make much difference if i built the 8 and double 15 into seperate boxes and then staked them on top of one another? |
jethrocker
Old Croc Joined: 07 June 2006 Location: Chiapas, Mexico Status: Offline Points: 1942 |
It wouldn't make a difference sound wise to build the sections seperately.., but you'd lose the advantage of the compactness of the xtro..
antimony
Im willing to loose the compactness to make something with less angles to cut
so do you use the horn mouth of both the 15 sections in hornresp? They share the back chamber right? Ive heard it said somewhere on the forums that when more than one driver is use in a horn they sum together to act as one. Is that the case here? |
Mircea Bartic
Old Croc Joined: 18 February 2005 Location: Romania Status: Offline Points: 2582 |
I ve posted some plots in "My version of the punisher and x-tro" tread
antimony
arnt they for the punishe? tho
Mircea Bartic
I remember plotting the X-tro too
Mircea Bartic
Mark James
aha cheers nexus. so im guesing to check out other drivers we just copy the top half of your input screen and put the drivers t/s for the model we are interested in simulating into the bottom half..... excelent
Mircea Bartic
yep
but remember to change the radiation angle to 2 pi |
Mark James
fantastic...
