  New Posts New Posts RSS Feed - X-tro build so far
X-tro build so far
 Post Reply Post Reply Page  <12345 6>
dylan-penguinmedia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dylan-penguinmedia Quote  Post ReplyReply Direct Link To This Post Posted: 16 July 2011 at 5:30pm
Looking good!
Another plus point for using the router to round off the edges is you'll find the paint will adhere much better to them, than if you don't do it.
godge View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote godge Quote  Post ReplyReply Direct Link To This Post Posted: 16 July 2011 at 5:34pm
yeah i took everyones advice and rounded over the edges the other day. its given them such a pro finish now. just waiting for some sunny weather so I can give em some coats of tuff cab.
thanks for the comments everyone, good to hear I'm doing an ok job
Post Options Post Options   Thanks (0) Thanks(0)   Quote godge Quote  Post ReplyReply Direct Link To This Post Posted: 17 July 2011 at 4:00pm
Originally posted by streetsounds streetsounds wrote:
ClapClapClap Very well built..envy your skill, what sort of drivers are you gonna install. What bottom speakers are you going to pair with this.
I'm loading the 8" with the B&C 8PE21, B&C DE500 on the compression and the B&C 15NW76 for the 15's. There all the recommended drivers apart from Instead of having the 18sound on the 15's went for the B&C instead.
I've currently got four stasys 5's which will be sitting under them but am looking at getting rid of them and getting some mini scoops instead, shame the scoop shoutout was cancelled cus I was looking forward to hearing some of them
Post Options Post Options   Thanks (0) Thanks(0)   Quote godge Quote  Post ReplyReply Direct Link To This Post Posted: 25 July 2011 at 5:07pm
A few updated pics, took advantage of the sunny whether and gave them a nice finish, that tuff cab paint is so easy to work with and gives a very nice finish. Will be loading in the drivers tomorrow.
smoore View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote smoore Quote  Post ReplyReply Direct Link To This Post Posted: 01 August 2011 at 11:37am
:O arrh so nice! Wish i had the skills!
Strange Daze View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Strange Daze Quote  Post ReplyReply Direct Link To This Post Posted: 05 August 2011 at 4:04pm
Killer build. Nicelly done Tom n Godge!!!
I'd love to see the 2nd horn a matching colour to the larger horn! :-)
loonie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote loonie Quote  Post ReplyReply Direct Link To This Post Posted: 06 August 2011 at 7:05am
Can you explain the routing done within the horns "enclosure/chamber" ?
Did you find the driver or horn didn't fit?
Team DB
tomschute View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomschute Quote  Post ReplyReply Direct Link To This Post Posted: 06 August 2011 at 9:42am
Nothing gets by you lot!
The Horn is quite big. To make it fit the kit included some rebates to fit snugly.
Tom
www.stableaudio.co.uk
Speaker Building Services
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 06 August 2011 at 11:22am
Paint that hf horn yellow too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote godge Quote  Post ReplyReply Direct Link To This Post Posted: 06 August 2011 at 1:46pm
Everything is a bit of a tight fit with this speaker I've found, there's just enough room to fit the 15" drivers in, I doubt very much that you could fit a driver in there that isn't a neodymium one without extending that read chamber by an inch or two.
It is rather a large horn and with the driver fitted on the back of it as well its quite a beast, I'm surprised looking at it that it actually fits inside that chamber at the top of the cab but it does slot in nicely.
With regards to the colour of the compression flare, I don't know what to do now you've given the idea of painting it the same colour as the 8". How about a vote, leave it as it is or spray it luminous yellow, most votes wins.
Contour View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Contour Quote  Post ReplyReply Direct Link To This Post Posted: 06 August 2011 at 5:40pm
Will the 8" get its own small back chamber as per the original design?
Best regards,
Walt
Post Options Post Options   Thanks (0) Thanks(0)   Quote godge Quote  Post ReplyReply Direct Link To This Post Posted: 07 August 2011 at 9:55pm
That's a very good point, just looked on the plans and can see it there.
Will it make much difference to it if it doesn't have its own back chamber acoustically wise
