  New Posts New Posts RSS Feed - xtro cutsheet?
xtro cutsheet?
craig582 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote craig582 Quote  Post ReplyReply Direct Link To This Post Topic: xtro cutsheet?
    Posted: 15 June 2013 at 10:32pm
hi guys n galls,
i appologise in advance, im prepared for the standard "use the search bar you f@*~"$g idiot" etc.
im after a cutsheet for two xtros, have just spent the past 1 1/2 hours trawling here and used the search and nothing,
would grately appreciate it if someone could point me in the right direction
cheers guys
b grade View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote b grade Quote  Post ReplyReply Direct Link To This Post Posted: 15 June 2013 at 10:55pm
I have not noticed a cut sheet, but surely in an hour and a half you could have come up with 4 or 5 different cut sheets with the aid of some graph paper.  Not intended as snark at all, just if someone does not link you to one pretty quick, make your own and post it for other folk to use in the future.  You can do it!!  ;)
Post Options Post Options   Thanks (1) Thanks(1)   Quote craig582 Quote  Post ReplyReply Direct Link To This Post Posted: 16 June 2013 at 12:05am
cheers b grade, as there is not one available i shall make one along with full cut sheets and parts lists
keep an eye shall post here
craig
tv00 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tv00 Quote  Post ReplyReply Direct Link To This Post Posted: 05 February 2015 at 6:00pm
Still watching...
Badger74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Badger74 Quote  Post ReplyReply Direct Link To This Post Posted: 17 March 2015 at 4:05pm
Originally posted by tv00 tv00 wrote:
Still watching...
LOLLOL
This page was generated in 1.656 seconds.
