Xtro flare redevelopement thread |
Page <1 234 |
gen0me
Joined: 20 February 2016 Location: UK Status: Offline Points: 995 |
Posted: 21 August 2017 at 1:33am |
5)
![]() ? ![]() Came to mind previous phase bungs. I have no idea why some frequencies are played one side of phase plug and a bit higher only another. Here is one more good horn. Reasonable dispersion up to 2.6kHz. 7.10.33.5 ![]() ![]() I was comparing different horns like Function 1 Resolution or Martin Audio H3. H3 has wide dispersion and plays up to 2k only. All Resolution's have very narrow dispersion and play really high. Like: 445hz - 5k77Hz >>> 25h x 20v 445hz - 5k77Hz >>> 50h x 25v Maybe its impossible with wide dispersion to go that high. |
toastyghost
Joined: 09 January 2007 Location: Manchester Status: Offline Points: 10932 |
Thanks(1)
Posted: 21 August 2017 at 2:28am |
The F1 horns actually get quite beamy at the upper register, you can see it on the isobars in the production partner review of the EVO.
gen0me
Posted: 26 October 2017 at 7:15pm |
Here is narrow dispersion longer one: 50cm wide, 40 high, 48.9 long(including plywood) to the driver.
![]() https://s1.postimg.org/5bjrsewb67/7_10_33_5_7final.jpg ![]() https://s1.postimg.org/5q2yxg06sf/7_10_33_5_7final_pic.jpg ![]() https://s1.postimg.org/4g01r4rmzj/7_10_33_5_7final_off_axis_response.jpg ![]() https://s1.postimg.org/2ojuae7pqn/7_10_33_5_7final_directivity.jpg 45H x 30V on top of the bandwidth. |
gen0me
Posted: 11 January 2018 at 5:46pm |
. Delete
Edited by gen0me - 11 January 2018 at 5:47pm |
Page <1 234 |
