Xtro flare redevelopement thread |
Page <1 234 |
gen0me ![]() Young Croc ![]() ![]() Joined: 20 February 2016 Location: UK Status: Offline Points: 999 |
5)
![]() ? ![]() Came to mind previous phase bungs. I have no idea why some frequencies are played one side of phase plug and a bit higher only another. Here is one more good horn. Reasonable dispersion up to 2.6kHz. 7.10.33.5 ![]() ![]() I was comparing different horns like Function 1 Resolution or Martin Audio H3. H3 has wide dispersion and plays up to 2k only. All Resolution's have very narrow dispersion and play really high. Like: 445hz - 5k77Hz >>> 25h x 20v 445hz - 5k77Hz >>> 50h x 25v Maybe its impossible with wide dispersion to go that high. |
toastyghost ![]() The 10,000 Points Club ![]() ![]() Joined: 09 January 2007 Location: Manchester Status: Offline Points: 10646 |
The F1 horns actually get quite beamy at the upper register, you can see it on the isobars in the production partner review of the EVO.
Here is narrow dispersion longer one: 50cm wide, 40 high, 48.9 long(including plywood) to the driver.
![]() https://s1.postimg.org/5bjrsewb67/7_10_33_5_7final.jpg ![]() https://s1.postimg.org/5q2yxg06sf/7_10_33_5_7final_pic.jpg ![]() https://s1.postimg.org/4g01r4rmzj/7_10_33_5_7final_off_axis_response.jpg ![]() https://s1.postimg.org/2ojuae7pqn/7_10_33_5_7final_directivity.jpg 45H x 30V on top of the bandwidth. |
. Delete
Edited by gen0me - 11 January 2018 at 5:47pm |
Page <1 234 |
