x-tro with x1??? |
unclejam
Young Croc Joined: 14 January 2006 Location: United States Status: Offline Points: 525 |
Posted: 23 October 2006 at 8:25am |
wouldit b a good combo and would i need anythin i between??? thanx
ceharden
Might be a little bit of a hole between the two, X1 probably doesn't quite go high enough. Would work tho.
unclejam
What Might go in between the combo???
ceharden
That would make for a five way system which might just be a little excessive. I suggest using a different sub. WSX's might work well with X-tro's
Or rethink what you're trying to acheive. |
Contour
Young Croc Joined: 03 March 2004 Status: Offline Points: 625 |
Hello,
I have not used X1 but the X-tro is usuable down to about 80Hz so I think it would be possible to match both cabinets. You can play with your crossover to fill a gap if a gap would occur.
Best regards,
Walt
