  New Posts New Posts RSS Feed - XTROdelays and x-over freq's
VPAS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote VPAS Quote  Post ReplyReply Direct Link To This Post Topic: XTROdelays and x-over freq's
    Posted: 16 May 2007 at 12:39pm
ive found some info on the crossover freq's but it says that it is only a rough guide
"In the future more exact processor settings will be given. As a guideline for now: crossover from sub to low at 90Hz, from low to mid at 300Hz and from mid to high at 2500Hz. One should use proper delays to compensate for the arrangement of the drivers in the X-tro cabinet."
what have other people found to be good freq' and also the delays as i have never used delay before but now have the ability to do so.
cheers
chris
Edited by VPAS - 16 May 2007 at 12:42pm
n^2 modulo -P = number wang
Mircea Bartic View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mircea Bartic Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2007 at 1:14pm
Ex Nexus_3
VPAS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote VPAS Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2007 at 1:22pm
perfect cheers, mircea
VPAS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote VPAS Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2007 at 12:34pm
i may be being stupid but what does this bit at the bottom mean
sub1
40-50Hz (depending on number of cabinets)
gain: personal taste
Q = 3-4
sub2
105 hz
-1,0 db
Q = 4,410
mid
2,25 khz
+ 4,0 db
Q = 1,215
high
14,3 khz
+1,0 db
Q = 1,789
norty303 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norty303 Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2007 at 1:46pm
Those are the parametric EQ settings used to give the desired response.
first bit is the frequency, second bit is how much gain is applied at that frequency and the last is Q (width) of the frequency band applied.
VPAS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote VPAS Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2007 at 3:24pm
nice one
