  New Posts New Posts RSS Feed - Yamaha s115h 2. 400 watt 8 ohm speakers
Foyle1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Foyle1 Quote  Post ReplyReply Direct Link To This Post Topic: Yamaha s115h 2. 400 watt 8 ohm speakers
    Posted: 27 May 2020 at 2:03am
Anyone tell me how to trouble shoot what’s wrong? I have two speakers one quit. Are used an ohmmeter and it seems that all the readings were the same as the speaker that work? I think it’s a crossover but I don’t have sound out of either speaker now. And can someone tell me where to get parts or what parts it might need if it is the crossover? What kind of ohm Readings should I have on different parts? Are the speakers worth fixing? I think I need bigger speakers but I would like to get these working anyway. Thank you for your replies
djeddie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote djeddie Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2020 at 2:03pm
Check your leads first... if one worked, and now bot don't, I'd guess there may be a problem there. It may even be the connectors on the amp/speaker/crossover/source etc etc.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Foyle1 Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2020 at 5:29pm
Hello thanks. But my other speakers work fine on same leads
This page was generated in 0.160 seconds.
