  New Posts New Posts RSS Feed - yet another laptop noise problem - hdmi
MattStolton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MattStolton Quote  Post ReplyReply Direct Link To This Post Posted: 04 February 2019 at 5:02pm
Are you taking audio out of the HDMI, or out of the headphone socket?
If out of headphone socket, or even a USB audio breakout, we use these pieces of nastiness, to remove hum, clicks, whirrs etc, that arise when PSU is plugged into mains and laptop...
http://www.avsl.com/product/201.086UK-ground-loop-isolator-rca-plugs-rca-sockets
Hate them but they work, every time...I'm sure if you measure one, the transformers saturate and don't transfer much below 50Hz, but that is less objectionable than the fizz of laptop PSUs.
If you want something posher, DI's with an earth lift switch tend to work, and give a balanced O/P.
Before I get flamed, I know that most PSUs are double insulated, so CPC is spurios and redundant, and the Laptop itself is SELV, and its "0v" is floating around in the ether or to "N", tied to only your mixers audio earth; but these cheap bodgit boxes just work. Easy to take apart, and hardwire cable of choice to the 2x 1:1 transformers PCB, and then tape or heat shrink the enclosure back together. And cheap.
Horrible things, but needs must.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MattStolton Quote  Post ReplyReply Direct Link To This Post Posted: 04 February 2019 at 5:05pm
Sorry, just saw your issue is with HDMI embedded audio. So much for noise free digital audio quality!
Perhaps extract audio from HDMI, into analogue, and then ping it into Hi-fi. Then if noise still present, cheap bodgit boxes?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MattStolton Quote  Post ReplyReply Direct Link To This Post Posted: 04 February 2019 at 5:13pm
HDMI over Cat5/6/7?
A lot of the things to extend HDMI past the notional 10M limit, and transfer by CatX cable, may well offr some form of galvanic isolation of the audio?
HDMI "RGB" is sent digitally, balanced (i.e. +1/0 and -1/0), but has a 0V core too. So there is three 0V. Audio is also digital data, but with a 0V reference, so another 0V ref, then the +5V has a 0V ref, and the overall screen!
Just thinking all that bodged over some form of CatX Tx/Rx set may get you down to just one 0V ref, which may help?
Whole range of them here:
https://cpc.farnell.com/c/computer-office/computing/extenders-splitters/cat5-extenders/hdmi-cat5-extenders/hdmi-extender-over-cat5
mini-mad View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mini-mad Quote  Post ReplyReply Direct Link To This Post Posted: 04 February 2019 at 5:20pm
Have you tried a USB to HDMI adaptor?
Maybe the noise won't be present on the USB sockets...
Post Options Post Options   Thanks (0) Thanks(0)   Quote MattStolton Quote  Post ReplyReply Direct Link To This Post Posted: 04 February 2019 at 5:24pm
Forget the TMDS clock has a screen too, so another source of 0V...And the DDC/EDID has a screen...but it still is 5 screens, and overall screen...
Post Options Post Options   Thanks (0) Thanks(0)   Quote MattStolton Quote  Post ReplyReply Direct Link To This Post Posted: 04 February 2019 at 5:26pm
IMHO, if Video 0V is noisey, Audio 0V is noisey, the USB bnus 0V will be even noisier!
Worth a try though, if you have one kicking about, strangest things can cure this noise.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mini-mad Quote  Post ReplyReply Direct Link To This Post Posted: 04 February 2019 at 5:33pm
The thought was the combined 0V rail MAY have an impact on the noise (in a good way) as they will all be steming from the same place on the USB output.
As you say... stranger things!
...to add, maybe a USB powered hub would isolate the laptops rails and then plug in a USB to HDMI adaptor... I know we are getting into the realms of silliness at this point but it saves removing the earth bond of the PSU or anything daft
Edited by mini-mad - 04 February 2019 at 5:36pm
godathunder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote godathunder Quote  Post ReplyReply Direct Link To This Post Posted: 04 February 2019 at 6:43pm
Originally posted by kedwardsleisure kedwardsleisure wrote:
that's going to be a hell of a linear power supply! It'll need to use a switching regulator to get that sort of current without a heatsink the size of a potato waffle
really? it seemed fairly sensibly sized to me -
Ive probably got a big enough 230-20ish v tx and rectifier etc somewhere
would I be able to parallel a pair of these to regulate it?
mounted on
watcha think?
edit: apparently paralleling regulators is not quite as easy as hoped
Edited by godathunder - 04 February 2019 at 7:58pm
LOUDER THAN LOUD
studio45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote studio45 Quote  Post ReplyReply Direct Link To This Post Posted: 05 February 2019 at 5:08pm
You can use a series pass transistor to handle the current, controlled by the regulator - you're still going to end up with a right heavy brick-like unit, though.
Conceptually, there's switching noise present on the audio because somehow, the path to ground via the HDMI has a lower RF impedance than the neutral connection of the power supply. Why that should be I couldn't say, but that will be the mechanics of what's happening. It all ought to be decoupled in the supply circuitry, but perhaps some caps are either missing or defunct?
Can you add a real earth connection - put on a 3-pin plug, add a green/yellow wire - and tie it to the power supply output's 0v side? Unsure of the safety implications of that, but it should ensure that the lowest impedance path for noise is not through the HDMI grounds any more!
Danielr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Danielr Quote  Post ReplyReply Direct Link To This Post Posted: 05 February 2019 at 5:40pm
Can you send video (assuming that is why you use hdmi) via HDMI.
But select the output audio device as headphones. Use regular line cable and ground lift as appropriate?
Not really helping you solve the problem, but maybe working around it?
APW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote APW Quote  Post ReplyReply Direct Link To This Post Posted: 05 February 2019 at 6:33pm
I suspect that heatsink is not up to the job, you need to work out the power being dissipated by the regulators pass element, to do this you need to know what voltage the regulator pass element is dropping and then multiply that by the maximum current it’s going to pass... then multiplying the calculated power by 2.3 (the heatsink in the link is 2.3°k\watt) to give you the temperature rise (in° kelvin) above the ambient temperature.
Is it possible for you to use a USB to HDMI converter for your video and sound, I ask as you can get a USB galvanic isolator?
https://uk.farnell.com/olimex/usb-iso/usb-isolator-1000vdc-for-pc-laptop/dp/1795095
The one in the link above is USB2, I have seen USB3 ones for about £70.00
Edited by APW - 05 February 2019 at 6:42pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote godathunder Quote  Post ReplyReply Direct Link To This Post Posted: 05 February 2019 at 7:26pm
thanks for some great suggestions chaps.
unfortunately, as I look at the cost and rather pointless complexity and added points of failure of putting hdmi-usb-isolator-usb-hdmi in the signal path I wonder why Im bothering when I know at heart that toasty nailed it in the 1st post.
if this was being installed somewhere where joe public or dj dave was being put at risk it would be worth the added cost etc but this is for my use only (well, and the kids, but I dont like them). I know the electrical install its being powered from is fine, has a nice low zs and suitably protected (I wired it). the hifi has its own dedicated circuit but the noise persists whether the laptop is powered from this, or an adjacent circuit
it annoys me to do it but I think that cutting off the mains plug and rewiring sans cpc is the best current option though building a linear psu will remain on the project list for the coming months
I think it just galls me that this seems to be such a common problem due to acceptance of cheap and shitty psu design in consumer goods
LOUDER THAN LOUD
