10 inch line array |
Post Reply | Page 123> |
stanley dj
Registered User Joined: 19 July 2013 Location: Ireland Status: Offline Points: 154 |
Posted: 27 May 2018 at 7:55pm |
hi all anybody have some plans of line array cabinets that works with eminence delta 10b have here 32 drivers and 32 compression drivers with dosc waveguides thanks all
P@Freak
Registered User Joined: 09 June 2013 Location: Germany Status: Offline Points: 50 |
V-Dosc Waveguides are for 10" Grid Dimensions ?!!
P@Freak
stanley dj
each cabinet will have 2x10 drivers maybe 2x6 Inch mid and 2x 1 inch compression drivers with waveguide something like l acustic ones have all except mid drivers .xover should be round 80 Hz for low and 1200hz for high
JonB67
If you do some searches on here you'll find no one is giving out line array plans because the time and cost involved in developing them means its only viable as a commercial venture.
But search anyway, you may find something useful in those threads.
stanley dj
i know is not sipmle I don't mind to spend some not crazy money all I need is the volume ,tuning of the lf driver cabinet to sound good and get Max is driver without damage
JonB67
Go and read as suggested if you're serious. You'll find that its not just volume and tuning for line array.
If you just want to build a few tops then download winisd, its a free piece of software that means you can easily work out just what you've asked. Loads of info on here and the net if you hit search and google. A quick heads up, the people on here will help with their hard earnt knowledge you if you want to learn, but may not spoon feed you the answers if you cant be bothered to put in any effort.
stanley dj
i read a lot I have my HF side sorted all my problem is now lf side. I done loads of research and experimental cabinets but I can't move any folder without help of somebody who done it before and all is cost me 2 much at this point so don't want to wasate more time and money without any more knowelage
JonB67
There are no free plans for line array. None. They're to expensive to r and d for people to give them for free.
What is it you are actually trying to do? If you just want help working out the volume and tuning to put a given driver in a midtop that's easy but its not what you've asked for so far... Jon
stanley dj
i want build line arrays not just mid/high cabs as I have drivers wave guides and all I need guide what type of lay out straight or in angle also need somebody who can design cabinet .to suit my drivers
citizensc
Serious question: Do you know the difference between lots of reflex mid-tops stacked on top of each-other and a line array? Like are you able to explain it in technical terms? If the answer is 'no' then you should probs try something a little more simple to start with. I have built maybe 20 or 30 cabs, designed and built my own reflex dj monitors and run a sound system for the last couple of years. I wouldn't even think about attempting to build a line array at this point. I know enough to know; I don't know near enough, if you know what I mean. Another serious question: What are you planning on using these speakers for? Do you have a specific genre, crowd size, location? or do you just sort of want to build a line array?
Edited by citizensc - 29 May 2018 at 1:54pm |
stanley dj
i need line array to fill out small town festival and usable to most genders of music I know few horn loaded cabs it makes but line array is chalange alslo I have drivers and I like to used it l
MarjanM
Just because you have drivers, it does not mean they are suitable for a line array box.
Slapping bunch of vertically hanged boxes, does not make it a line array. It is much more complex then that. Hardware is a whole another story. You must certify it if you want to fly the boxes in public.
