12 light connector |
BrainlessTekno ![]() Registered User ![]() ![]() Joined: 20 February 2023 Location: Slovakia Status: Offline Points: 164 |
![]() ![]() ![]() ![]() ![]() Posted: 24 July 2023 at 11:48am |
Hi,
sorry but i have no experience with lights so please try to explain even basic details to me :D Im looking to connect police light in my system but im not sure what to do. Its 12V so i have autobatery to power it but the light have wierd connector that i have never seen before. Should i cut the cable and look for positive and negative cable and soldier it to make it connect to baterry ? ![]() ![]() Edited by BrainlessTekno - 24 July 2023 at 11:57am |
teeth ![]() Registered User ![]() Joined: 05 July 2021 Status: Online Points: 452 |
tbh, i would crack it open and see what's connected to what inside. trying to use that connector would be more trouble than it's worth
okey sound good... will i be able to identify positive and negative wires by the color or should i check where the wires are going ?
dunno, you'll have to work it out, no idea whats inside. send a pic, can try and help...
So, i did manage to open it and play with cables. a little, separatly i can power each light that means 4x flashing lights and 6x stropes. however i removed couple boxes from the middle because i was not sure what were they doing.
My next question is... Flasihng lights are just OK as they are but for the strobes to be used on a gig i need them to flash, i come up with an idea to instal a switch on the cable but who wants to slam the switch every second right ? is there some machine that i can easily install to get the flashing ? how is it called and what are my options ?
