  New Posts New Posts RSS Feed - 15 or 18mm?
15 or 18mm?
Smitj082 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Smitj082 Quote  Post ReplyReply Direct Link To This Post Topic: 15 or 18mm?
    Posted: 14 March 2013 at 12:49pm
http://www.speakerstore.nl/constructions/show/21 on this plan it says to use 15mm birch ply, but i thought most cabs were made out of 18mm?
Is this the correct way or should i find a plan with 18mm ply
Post Options Post Options   Thanks (0) Thanks(0)   Quote Smitj082 Quote  Post ReplyReply Direct Link To This Post Posted: 14 March 2013 at 1:01pm
didnt mean to post this twice... does anyone know how to delte a post?
doober View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote doober Quote  Post ReplyReply Direct Link To This Post Posted: 14 March 2013 at 4:47pm
Yep, use 15mm. That's what I built all of mine from. Make sure it's good quality birch throughout.
Blahblahblah
odc04r View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote odc04r Quote  Post ReplyReply Direct Link To This Post Posted: 14 March 2013 at 5:44pm
15mm is fine, you have loads of bracing internally. Proper builds are ridiculously strong. And one is actually quite weighty, so I would not want to lift an 18mm version solo.
mirenkoo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mirenkoo Quote  Post ReplyReply Direct Link To This Post Posted: 06 April 2013 at 9:19pm
I've used 18mm but I don't think there is any difference in sound/quality. Go for 15mm as my punisher weights 70kg!!
