18" scoops build advice needed please.. |
Page 123 6> |
bill-77
Joined: 13 October 2007 Location: United Kingdom Status: Offline Points: 102 |
Topic: 18" scoops build advice needed please..Posted: 21 November 2007 at 9:11pm |
hi all forum members i,m planning to build x6 standard scoop box,s old school style...what i would like to know from the exsprienced in forum is how many 8ft by 4ft sheets of ply wood will i be needing for a single scoop box? i will be using the measurments from my other x2 scoops...... and would the standard wicks ply wood be ok to use ? £22 a sheet....or will i need to use the exspensive marine birch ply wood ?.....i have built small scale box,s in the past but nothing to what i,m in the process of doing ,,so i have some exsprience..tips and suggestions from the the exsprienced would be appreciated many thanks regards bill
Edited by bill-77 - 21 November 2007 at 9:12pm |
WISDOM IS BETTER THEN SILVER AND GOLD!!
TONY.A.S.S.
Joined: 21 February 2007 Location: United Kingdom Status: Offline Points: 6867 |
Posted: 21 November 2007 at 9:23pm |
Just use muti-laminate ply. Normal baltic birch isn't marine ply. I assume you have the cutting list, so draw your parts on to a scaled down 8x4, and then you'll have the answer. It'll be a good way of familiarizing yourself with the forth comeing project.
bill-77
Posted: 21 November 2007 at 9:32pm |
nice one tony a,s,s i appreciate your advice ....tony i heard alot of people use car chip spray to spray the cabs,,whats your opinion on this ? ..my other x2 scoops are painted with standard paint,,,what would be the best paint to use? somthing durable and long lasting thanks bill
LostGrayCat
Joined: 22 August 2005 Location: United States Status: Offline Points: 1053 |
Posted: 21 November 2007 at 10:43pm |
TONY.A.S.S.
Posted: 21 November 2007 at 11:07pm |
As a manufacturer, I've always stuck to pretty std. stuff In my position, I've always had to concern myself with production. Which means easy access from a reputable supplier, and buying in quantity always gets a good price. There could be some amazing material out there, that could used in a one off situation. If you went into production with car chip paint to do it properly would cost a fortune with the specialized equipment. It's unlikely that Fords use a can.
bill-77
Posted: 22 November 2007 at 9:47am |
thanks guys i,m gonna give this project a try
Static Age
Joined: 14 November 2005 Location: Oxfordshire Status: Offline Points: 1652 |
Posted: 22 November 2007 at 10:23am |
i'm close to finishing off a pair of scoops myself at the moment, you will use the best part of two 8x4 sheets of ply per cabinet as the sides of scoops are quite large. dont forget to budget for the thinner sheets of ply you need to form the actual scoop part.
scoops are fairly easy to build as there are no particularly difficult cuts required, so i wouldnt bother with a chip board proto type.
bill-77
Posted: 22 November 2007 at 3:15pm |
Static Age
Posted: 22 November 2007 at 4:00pm |
i will be fitting Fane Colossus 18XB's in my scoops to match my other scoops.
here is a handy tip from Rog regarding the scoop section...
'To make the curved part of the horn flare bend a piece of 3 mm plywood around some battens that have been glued and screwed to the side walls to form the curve, then glue and nail another piece of 3mm plywood on top of the first piece. Keep doing this with another 4 pieces of 3 mm plywood until you have all 6 pieces glued and nailed together. The finished curve should now be 18 mm thick. For a better job use 4 pieces of 18 mm ply to make the curved former. Use a jigsaw to cutout the curve from the 18 mm ply and glue and screw them in place evenly spaced across the width of the curve. The 2 outer most formers should be positioned right against the cabinet walls.'
bill-77
Posted: 22 November 2007 at 4:24pm |
Static Age
Posted: 22 November 2007 at 4:30pm |
Bill, thats not my build. that pic is a super scooper built by Dom, the pic is taken from the readers projects section on the sepakerplans home page, see...
I posted the pic as an example on how to assemble the 'scoop' part.
my scoops are currently at a similar stage but minus the scoop, i will get some step by step pics up when i have finished the project.
Dan.
bill-77
Posted: 22 November 2007 at 5:02pm |
oh ok sorry thought that was your build lol ,,,i was wondering that looked very diffrent from the old school classic scoop lol ..static those pictures of yours would be very handy and educational for beginner project builders like my self ..will be looking forward to seing them |
Page 123 6> |
