18" scoops build advice needed please.. |
Page <1 3456> |
| Author | |||
Father-Francis
Joined: 24 October 2007 Location: Kenya ,Denmark Status: Offline Points: 2758 |
Posted: 27 November 2007 at 12:00pm |
Nice one Lev |
Tekasis
Posted: 27 November 2007 at 1:36pm |
Over the years, we've come across scoops which actually sound better in chipboard & MDF than ply! Not too sure if this all depends on the type of cab.
tweeter box
Joined: 21 October 2007 Location: United Kingdom Status: Offline Points: 6784 |
Posted: 27 November 2007 at 2:03pm |
Wicked build pics Static
Scoops look well nice, bet they gonna sound the buisness aswell.
bill-77
Joined: 13 October 2007 Location: United Kingdom Status: Offline Points: 102 |
Posted: 27 November 2007 at 5:04pm |
hi all been buisy doing over time to pay for the materials needed..just managed to get a second hand bench saw for 60 pounds from ebay...scary piece of kit to use that 10 inch blade looks and sounds dangerous when powerd up lol ..i thought using my airtools at work where bad enough...got x2 sheets of ply and just need to measure and mark then cut.. gonna ask me nephew to come and assist coz that sheet of ply is dam heavy..
WISDOM IS BETTER THEN SILVER AND GOLD!!
Static Age
Joined: 14 November 2005 Location: Oxfordshire Status: Offline Points: 1652 |
Posted: 27 November 2007 at 5:31pm |
i cut each 8x4 sheet seperately. plan your cuts carefully to get the most out of your sheets, you will find the scoop side panels are the biggest panels to cut out.
bill-77
Posted: 27 November 2007 at 5:43pm |
Edited by bill-77 - 27 November 2007 at 6:39pm |
tommysb
Joined: 24 April 2006 Location: Finland Status: Offline Points: 1036 |
Posted: 27 November 2007 at 8:29pm |
Just take things slow, do a panel or 2 in each session and don't rush!
bill-77
Posted: 27 November 2007 at 8:38pm |
Static Age
Posted: 29 November 2007 at 1:50pm |
i had a little break from the scoop build since the last lot of pics, but last night i put a couple of hours work in..
heres the formers for the actual scoop bit. i decided to use the curved formers as recomended in the super scooper plan, i also added a 50mm wide horizontal brace which i mounted into the curved formers via cut outs for extra strength.
adambomb
Joined: 10 April 2006 Location: United Kingdom Status: Offline Points: 3220 |
Posted: 29 November 2007 at 2:06pm |
fill it with sand!
tweeter box
Posted: 29 November 2007 at 2:19pm |
Hi adam could u explain this pls?
mykey
Joined: 18 August 2005 Location: UK/Indonesia Status: Offline Points: 9680 |
Posted: 29 November 2007 at 2:48pm |
not practical
very good static using the ribs
we did that in the XXL's and doing the same in the DubSubs
you should have left the back off though so you can see if there are any gaps to fill
in the dubsub its ok because of te piece missing for the castors
will be proper when you've finshed them
good to have the photo history of the build as well when you go to sell them
Page <1 3456> |
