  New Posts New Posts RSS Feed - 18" scoops build advice needed please..
 Post Reply Post Reply Page  <1 456
Static Age View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Static Age Quote  Post ReplyReply Direct Link To This Post Posted: 29 November 2007 at 3:17pm
i could see if there were any gaps by looking through the handle cut outs on the bottom.
cheers for the positive coments mykey
bill-77 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bill-77 Quote  Post ReplyReply Direct Link To This Post Posted: 29 November 2007 at 5:09pm
Originally posted by Static Age Static Age wrote:
i had a little break from the scoop build since the last lot of pics, but last night i put a couple of hours work in..
heres the formers for the actual scoop bit. i decided to use the curved formers as recomended in the super scooper plan, i also added a 50mm wide horizontal brace which i mounted into the curved formers via cut outs for extra strength.
very nice static ..very detailed and clean work well doneWink....just about got my pieces cut lool
WISDOM IS BETTER THEN SILVER AND GOLD!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Static Age Quote  Post ReplyReply Direct Link To This Post Posted: 29 November 2007 at 9:44pm
pics from tonights build session.
scoops now in, battens for grills fitted & screw holes filled.
mykey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mykey Quote  Post ReplyReply Direct Link To This Post Posted: 01 December 2007 at 3:17pm
Clap solid , will be around for years
you gonna put a nice cross brace in
and why did you miss out the dog leg? (triangle piece)
battens around the mouth are a bit large though?
i'll do you a drawing of what i think you should have done and a few other members mite want to do it as well , its what i used to do on my other scoops
Edited by mykey - 01 December 2007 at 3:19pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Static Age Quote  Post ReplyReply Direct Link To This Post Posted: 01 December 2007 at 4:42pm
i will be fitting a cross brace in the mouth, i left it out to make it easier to get in & paint the inside.
the triangle piece isnt present on the scoops i copied so i didnt put it on these.
again the battens are the same size as on my other scoops, they do look quite big but they dont stand out as much when painted.
Mykey, thanks again for the constructive comments, i would like to see your drawing.
like i said my other scoops do not have tha dog leg (triangle bit) & they sound great.
does it really have much of a difference to the sound? if so i might do with/ without comparrison test with some working cabs.
Dan.
Edited by Static Age - 01 December 2007 at 4:43pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote bill-77 Quote  Post ReplyReply Direct Link To This Post Posted: 03 December 2007 at 8:29pm
[/QUOTE] []static those scoops are aboslutely solid well doneClap..and thanks again for making the effort to post your project pictures on here Wink....been a very buisy dude just about got the first finished thanks for the guidence and tips stactic age  ..will be posting very soon..
Edited by bill-77 - 03 December 2007 at 8:33pm
Mark James View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark James Quote  Post ReplyReply Direct Link To This Post Posted: 03 December 2007 at 8:42pm
pics then bill? lol...
insert silly sentence here
Post Options Post Options   Thanks (0) Thanks(0)   Quote bill-77 Quote  Post ReplyReply Direct Link To This Post Posted: 03 December 2007 at 8:50pm
lol very soon my friend ,messed up on the first then had to rebuild it Embarrassed..not easy for a newby lol getting there though LOL
ToNy MoNtAnA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ToNy MoNtAnA Quote  Post ReplyReply Direct Link To This Post Posted: 11 December 2007 at 1:30am
Love how you did the bracing and battons, Static Age.
APSUS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote APSUS Quote  Post ReplyReply Direct Link To This Post Posted: 17 January 2026 at 10:02pm
Can I get away with using 3mm for the scoop and use expansion foam behind the scoop or would that be too weak? Could I use fiber glass on the scoop to make it stronger? Or just use 2 x 18mm birch ply panels angled.
njw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote njw Quote  Post ReplyReply Direct Link To This Post Posted: 17 January 2026 at 11:39pm
 3mm is fine if you layer a few pieces on top of each other with plenty of glue inbetween, I've done lots of cabs like this, you can get away with 6mm if the radius isn't too tight. If you build around a former it makes for a super strong cabinet too.
BadmanSS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BadmanSS Quote  Post ReplyReply Direct Link To This Post Posted: 24 January 2026 at 2:49pm
I'm new to this and would love to build my own but don't know where to start.   I love this build but it looks intimidating.
Do you happen to have the measurements.   I like this and the golden horn design, but not sure what direction to go. Any help would be highly appreciated.   I don't mean to hijack your thread but would greatly appreciate your help because it seems like you were in the same boat as me recently.   I asked around for ppl to build for me but their prices are ridiculous.
