  New Posts New Posts RSS Feed - 1800w driver
1800w driver
WaveLength View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WaveLength Quote  Post ReplyReply Direct Link To This Post Topic: 1800w driver
    Posted: 05 January 2026 at 12:07pm
Hi guys
Happy 2026
I'm thinking to upgrade my sub section and move to a more powerfull driver
I see that there are few 1800w around
Can i have a good advice on what would be the best to buy and that will work in suoerscoops?
levyte357- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 06 January 2026 at 9:46am
Originally posted by WaveLength WaveLength wrote:
Hi guys
Happy 2026
Which drivers are you using in them now?
Not many drivers are optimum in the 18" Superscooper, would think Void V18-1000, is one of the best,  the unmodified Scooper.
Modify the throat section, then things change..
Post Options Post Options   Thanks (0) Thanks(0)   Quote WaveLength Quote  Post ReplyReply Direct Link To This Post Posted: 07 January 2026 at 9:36am
I have void v1000 in supers now
But i Just want to get a more powerfull driver
I can even consider tò switch superscoop with another design
Edited by WaveLength - 07 January 2026 at 9:37am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Earplug Quote  Post ReplyReply Direct Link To This Post Posted: 07 January 2026 at 1:23pm
How many more (or LESS!) dB's will that give you? dB's are far more important than power rating, never mind a dozen other parameters to take into account. And what about amps? Will you have to buy a new (bigger/more expensive) amp/s? The Void driver is optimum for those cabs. "Upgrade" at your own risk.
jammin75 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jammin75 Quote  Post ReplyReply Direct Link To This Post Posted: 07 January 2026 at 1:38pm
add more supers or change box Big smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 07 January 2026 at 1:40pm
To upgrade to drivers superior to the V18-1000 in Scoops, you will need another plan.
My Lev .44 Scoop, works with some of these drivers, but I'll never sell those.
I do have another plan, I developed, and one prototype for it.
Get in touch if interested.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WaveLength Quote  Post ReplyReply Direct Link To This Post Posted: 07 January 2026 at 2:15pm
I know that the output loudness Will not be diubled
I Just Need a Little more Power 🤪
Also i already have a cvr 4ch (2000w8r) tò drive 4x 1800w driver
I can't add more boxes cause i have not enough space in my home.
What design i should go for ?
Fane scaled up- Hugo full scoop- cow scoop?
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 07 January 2026 at 2:26pm
Before considering changing drivers or cabs.
I would suggest replacing that CVR amp, with Void Infinite 8 MK2, or Admark AD60 amplifier.
As I can guarantee that CVR is not powering those Void drivers properly, especially down to 40hz.
Edited by levyte357- - 07 January 2026 at 2:39pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote WaveLength Quote  Post ReplyReply Direct Link To This Post Posted: 07 January 2026 at 2:46pm
My 4 v1000 have Always been drived by a 5000vz
I would use the cvr Just on a 1800w
Anyway i tested the cvr with Smaart  and the freq response was pretty flat down tò 30hz
Edited by WaveLength - 07 January 2026 at 2:57pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 07 January 2026 at 2:58pm
My 4 v1000 are Always been drived by a 5000vz
Even a Macrtotech MA5000VZ, on 32A, would not fully power, 4x 8 ohm Voids.
A Void Infinite 8 MK2, on 32A, would power 2x of those Voids per channel, better than a Crest 9001, and can assure you, your CVR will not match that, despite what the specs say.
Only amps, that will power 4x subs better than a Void Infinite 8 MK2, are Admark AD60, Powersoft K20, or Powersoft X4L,  or pair of bridged QSC RMX 5050.
Edited by levyte357- - 07 January 2026 at 3:02pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote WaveLength Quote  Post ReplyReply Direct Link To This Post Posted: 07 January 2026 at 3:11pm
A 5000vz can do It .. with the ioc led constantly blinking 😂
Really thx tò share Ur knowledge Lev
I Always wanted tò buy an infinie8 MK2 but i Never found One for sale when i had money
Post Options Post Options   Thanks (0) Thanks(0)   Quote WaveLength Quote  Post ReplyReply Direct Link To This Post Posted: 07 January 2026 at 3:13pm
A 5000vz can do that... With the ioc led constantly blinking 😂
Really thx to share Ur knowledge Lev
I Always wanted to buy and infinite 8 MK2 but i Never found One for sale when i had money
