  New Posts New Posts RSS Feed - 1850 based system, top end?
solidbaseseven View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote solidbaseseven Quote  Post ReplyReply Direct Link To This Post Topic: 1850 based system, top end?
    Posted: 27 April 2008 at 2:26am
Hi I am going to build a system with 4 1850's each side, I am going to use 4 Wharfedale MP-2800's to power them, and need suggestions about what sort of tops to use. I am going to use these for both live sound reinforcement, and also dance music including D&B. I have read other posts, and they advise that the MT122 is about right, however I have concerns about the top end not being up to the job, and am a bit reluctant to go 4 way. I also would appreciate any suggestions anyone may have as how many I would need per side in order to keep up with a stack of 4 1850's, cheers guys.
Hi_Varu View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hi_Varu Quote  Post ReplyReply Direct Link To This Post Posted: 27 April 2008 at 10:55am
         -4 186 +4 hd15+2 mt 102 (better solution for modulability )
or      - 4 1850 +2 mt122   for dance.(not so good in live)
Mark James View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark James Quote  Post ReplyReply Direct Link To This Post Posted: 27 April 2008 at 12:21pm
nonono hd15 and 1850 do a similar range, not enough difference to make them realy worth delibrately building as a combo.
xtro is an option but youd need to think about placement and splaying.
kick cabs are a good idea with the 186/1850 if you ever want to play tekno or anything kick driven to be honest.
insert silly sentence here
Heathrow_B_line View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Heathrow_B_line Quote  Post ReplyReply Direct Link To This Post Posted: 27 April 2008 at 12:49pm
just build more 1850s and run them up to 20khz
job done
mstep77 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mstep77 Quote  Post ReplyReply Direct Link To This Post Posted: 27 April 2008 at 2:21pm
4 1850 horns to two porn horns.
Post Options Post Options   Thanks (0) Thanks(0)   Quote solidbaseseven Quote  Post ReplyReply Direct Link To This Post Posted: 27 April 2008 at 10:30pm
I have spoken with a good friend, and he thinks that 6 x 1850's per side would be better with 2 x decent 1 x 12" driver + 1.5" Compression driver loaded cab combo's for the tops, would that be enough mid and treble?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark James Quote  Post ReplyReply Direct Link To This Post Posted: 27 April 2008 at 10:57pm
maybey, for live work maybey double 12" [2 per side] would be better, a little more in the 200hz<800hz lower vocal range if you get me, like the mt122 or a porn with two 12" porn mf sections and 1 1.4" [I think} hf sections, job done, two per side and 6 1850 horns per side would cetainly rock some of the larger out door events with a fair sized crowd for any music to be honest,
Post Options Post Options   Thanks (0) Thanks(0)   Quote solidbaseseven Quote  Post ReplyReply Direct Link To This Post Posted: 28 April 2008 at 2:46am
So you recon that the MT112 (2 per side) would be a good choice, what do you think about components for these, use the recomeneded ones? or go with a slightly smaller diameter comp driver to reach the higher end of the spectrum? I don't really want to go for porn horns, mainly because I can imagine that the horn/driver combination would cost an absolute fortune (it would be 8 in total). If I were to bite the bullet, and go for a four way stack (1850-Bass, MT122-Mid-Mid top, and then either a stand alone compression driver or super tweeter for the  very top end) what sort of comp driver/super tweeter should I use? and how many? Thanks for the interset in my predicament by the way.
Post Options Post Options   Thanks (0) Thanks(0)   Quote solidbaseseven Quote  Post ReplyReply Direct Link To This Post Posted: 28 April 2008 at 2:59am
Oh yeah, thought I should mention, this rig will be used indoors too, I am trying to set a standard for local PA hire (my side line business/hobby), and am hoping to hammer the local competition, I will also be providing 4k of monitors through 8 2x12" + 1" wedges (designs adapted from the H.A.R.D. 212) as I am sick of bands saying "I can't hear anything through my monitor" whilst standing in front of thier cranked up marshall half stack, looking puzzled as I try to explain that their onstage sound is too, but that is a different story.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark James Quote  Post ReplyReply Direct Link To This Post Posted: 28 April 2008 at 8:09am
guitarists who cant hear sweet fa through the monnitors lol. been there, actualy sort of was one of them but not as bad as some, tbh throwing more volume at them never helps to be honest lol.
but yeah a pair of mt122 as of the plan per side would be grat but id be tempted to go 12"+6.5" +1" to get more of the vocals/mid ontop paper and get the heigh end clearer due to the 1".
x-tro is possible 2 per side. not sure if the mids wouldd be loud enough though..... hmmmm.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hi_Varu Quote  Post ReplyReply Direct Link To This Post Posted: 29 April 2008 at 11:34am
for play techno...
...  set the 1850 crossover at 100hz  and the hd 15 at 180.from 180 the mt 102..
sound colouration of 1850  from 100-200 isn't the best..
Edited by Hi_Varu - 09 June 2008 at 12:16am
ArthurG View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ArthurG Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2008 at 6:04am
Originally posted by Hi_Varu Hi_Varu wrote:
I play techno...
... i set the 1850 crossover at 100hz  and the hd 15 at 180.from 180 the mt 102.they kik hard.
and what about "sound coloration" at 180Hz with HD15 ? Confused
