1850 based system, top end? |
Post Reply | Page <12 |
Mark James
exactly, the best thin I could think of especialt for tekno would be 4 186 or 1850 with a pair of xtro
Saul
Old Croc Joined: 15 June 2007 Status: Offline Points: 5912 |
1 x mt121 per 2x1850 is good, the mt121 cab can comfortably meet the 1850's top end. |
Mark James
yes nice set up, but a four way with a proper kick section may be better for cerain types of music.
depends on what you do I suppose! |
rezsbc
Registered User Joined: 21 November 2006 Location: Ireland Status: Offline Points: 352 |
the 1850 is a one-way bass cab.... plays too low to make a sub-bin worthwhile... too high to make a kick-bin worthwhile...
I think they sound great for techno and the likes. I'd run two high quality mid tops over 4 1850's. Porn horns yes but you say that would be pricey. MT122's would seem like a good choice.... not sure what frequency they play down to but I've heard them in combination with 1850 horns and it sounded very nice indeed.
I seriously doubt you will be disappointed with that combination.
streetsounds
Registered User Joined: 12 July 2008 Location: Santa Rita Status: Offline Points: 301 |
I would go for four 186 with two mt 122 per side.
Bass matters...
stusparty
Registered User Joined: 17 September 2007 Location: United Kingdom Status: Offline Points: 489 |
It depends what drivers you put in the MT122's. I have 1 pair that are plenty enough for 4x1850's and I also run 2 USB's on top of the 1850's for added punch. used for DnB and bassline it sounds amazing. infact I turn the mt122 amps down a bit as they are too much sometimes.
streetsounds
At what freq do you cut your 1850's and USB's. You are right ive got a pair of enclosure pretty similar to MT 122 with dual P Audio 500 watts mid and a 2" throat P audio hi and the ratio is 1 is two four 186.
Bass matters...
