1850 - Horn build |
Page <123> |
| Author | ||
studio45
Joined: 16 October 2007 Location: United Kingdom Status: Offline Points: 3881 |
Posted: 26 December 2009 at 5:25pm |
Why don't you like bi-amped tops? they are better in every way!
If it's because you want to be able to use only two, 2-channel amplifiers to run this system, just run in Mono until you can get another amp! Most amps will easily drive 2x tweeters from one channel and 2x woofers from the other... It is true the Turbosound models you mentioned are old, but they are still very, very good, and would be a good match for your horns. The woodwork is of a similar high standard, for a start :) You may want a mid-bass box or kick-bin between them, though. If you don't like "selfmade" ("DIY" is a better way of saying that) midtops, you haven't heard a good one! (....like mine ) |
Chrise
Joined: 22 November 2009 Location: Germany Status: Offline Points: 50 |
Posted: 26 December 2009 at 5:39pm |
Edit
Edited by Chrise - 25 January 2010 at 1:45pm |
[GER-User]
Chrise
Posted: 16 January 2010 at 6:12pm |
Edit
Edited by Chrise - 25 January 2010 at 1:46pm |
[GER-User]
breakdabeat pete
Joined: 10 March 2008 Location: norwich Status: Offline Points: 758 |
Posted: 16 January 2010 at 11:11pm |
id strongly consider the mt121 crossing from the 1850's at around 130hz |
٩(̾●̮̮̃̾•̃̾)۶
Saul
Posted: 16 January 2010 at 11:16pm |
what's the big slot on the back of your boxes for?
i like the brace design - is it part MDF, part Ply though?
cravings
Joined: 30 January 2007 Location: Ireland Status: Offline Points: 7507 |
Posted: 17 January 2010 at 12:21am |
the construction is excellent. the braces do look slightly dangerous though! some drunk head falling against one may not come off too well. am i being overly negative?
Chrise
Posted: 17 January 2010 at 2:26am |
its a handle ... if you stand behind the cab and you must pull them backward ... ;) Jep, basicly MDF, but now I have some cheap ply (6,80€ m²) So I have made the rest of ply. |
[GER-User]
Chrise
Posted: 17 January 2010 at 2:27am |
No not a mt121, out there are many better midtops ... |
[GER-User]
DjJosh
Joined: 22 September 2009 Location: Estonia Status: Offline Points: 30 |
Posted: 17 January 2010 at 3:35pm |
mt 130 :)
Chrise
Posted: 17 January 2010 at 8:24pm |
e.g. :D
[GER-User]
DjJosh
Posted: 18 January 2010 at 4:38pm |
AlfieDring
Joined: 04 September 2006 Location: Bath, UK Status: Offline Points: 842 |
Posted: 18 January 2010 at 5:11pm |
No vertical expansion?? Whats the intended crossover point? Alf |
Page <123> |
