  New Posts New Posts RSS Feed - 1850 upgrade
1850 upgrade
kilowattsounds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kilowattsounds Quote  Post ReplyReply Direct Link To This Post Topic: 1850 upgrade
    Posted: 07 July 2022 at 12:00pm
Hi all looking at a few suggestions as an alternative to pd1850 your views would be greatly appreciated 😊
MORE BASS LESS BEEF INCREASE THE PEACE !!!!!
my facebook page
levyte357- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 07 July 2022 at 10:50pm
All depends on your cabs, and what will fit, and which amps you have, sir.
18NLW9601, is defacto upgrade, but no point, unless you have real 2kw to put in each driver.
Also too deep for many 1850 Scoops.
APSUS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote APSUS Quote  Post ReplyReply Direct Link To This Post Posted: 09 July 2022 at 3:56am
Are any sounds using the 18NLW9601? Has anyone heard them in person.
paulus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote paulus Quote  Post ReplyReply Direct Link To This Post Posted: 09 July 2022 at 10:00am
The b and c sw115 is one of the best drivers in have heard for ages was in some deep chamber scoops but the power and low notes were something else ,but again a deep driver
TRENDSETTER SOUND SYSTEM
fatfreddiescat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fatfreddiescat Quote  Post ReplyReply Direct Link To This Post Posted: 09 July 2022 at 2:41pm
Precision Devices PD.1845-1N has very similar T/S specs to the B&C SW115 and is less expensive, may be worth a look.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 09 July 2022 at 5:23pm
Some do use it :)
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 09 July 2022 at 7:36pm
By all reports sound good.
But it's followers, hate to accept, the lower BL, is a consideration, not to be ignored..
Post Options Post Options   Thanks (0) Thanks(0)   Quote fatfreddiescat Quote  Post ReplyReply Direct Link To This Post Posted: 09 July 2022 at 9:25pm
True it has a lower BL but motor force compared to mms is marginally better for th PD. One heading my way to try out, good to hear that they sound 👍
Edited by fatfreddiescat - 09 July 2022 at 9:31pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 12 July 2022 at 8:44am
Luckily, I designed my Lev .44 Scoops, to be optimal for PD1852, and other similar modern drivers..
So PD1850 is not all that in my Scoop, but the PD1852, PD1851 and even 18NLW9601, really smash in them.
Sure the big boy B&C would as well, but I'm not enlarging cutout in my cabs, to try them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 12 July 2022 at 12:05pm
Come to think of it, at least 1x well known UK Roots system upgraded from 1850s in their small chamber ASS Scoops, to PD1852s, and apparently sound very impressive, when they bridged CA18, per pair of cabs.
djkeet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote djkeet Quote  Post ReplyReply Direct Link To This Post Posted: 12 July 2022 at 8:19pm
Actually there as been some good reviews on the PD 1845 but its specs are more closer to B&C 18DS100,which also requires a bit of room, out of all them NEO's you will get away with a 9601 with ease (with shims or cut out baffle) if its the design I think you have, try finding one them (9601)2 hand gold dust never heard of any sound system blowing them, construction is also good. B&C SW115 is also good musical driver. PD 1852 would prob drop straight into your cab without having to cut out more of your baffle. To get a more clear idea ask (P) to run some of these drivers in HR (Horn response) and see what comes out ideally with the amount of money involved you could do with someone also measuring the impedance curve of your scoop/driver and finally real worl testing if poss. By having as much info you will be in a better position to make a decision.
Edited by djkeet - 12 July 2022 at 10:48pm
Soundbite
Post Options Post Options   Thanks (0) Thanks(0)   Quote kilowattsounds Quote  Post ReplyReply Direct Link To This Post Posted: 13 July 2022 at 11:06pm
Many thanks guys some excellent points .....I did try the 1852 & yes impressive but always good to consider all options
my facebook page
